Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 08-09-2013, 05:27 PM   #21
1986 27' Sovereign
Mogadore , Ohio
Originally Posted by Tony Burton View Post
Hi John,
I need a new door handle for my 1983 Limited. Please send me contact information.
Tony
Hi Tony, Yes I have a stainless handle that may fit your limited. The handle should fit trailers 1978 to 1993 but there are a few exceptions. The easiest way to tell is the size of the handle - mine is 2" wide x 4" high. if you could verify this we can go from there. Contact me at j.boxmaker@sbcglobal.net.
John
John Burkey is offline   Reply With Quote
Old 01-20-2014, 01:40 PM   #22
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Originally Posted by John Burkey View Post
Hello,
Just to let yoy guys know, I make a stainless steel replacement handle for 1978 to 1993 entry door. I made the first one for me and decided to make it available to others.
I just replaced my broken handle with one of John's stainless replacements. Excellent workmanship plus dummy-proof instructions. Thank-You John. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 03-30-2014, 01:05 PM   #23
Full-timer
nickglase's Avatar
1988 34.5' Airstream 345
new york , New York
Hi John,
Our handle just broke here and we'd be interested in one of yours.
I'm at nickglase@gmail.com .
Nick
Urban camping in San Francisco, Ca
1988 Airstream 345 Motorhome
1964 Vespa GS
1982 VW Qauntum, turbo diesel
1979 Triumph Spitfire 1500
nickglase is offline   Reply With Quote
Old 07-13-2014, 11:51 AM   #24
1978 31' Excella 500
Eden , Utah
I also need a paddle handle for my 1978 Excella 500 how do I get in touch? My e-mail is bajabill@digis.net
Thanks in advance.
BajaBill is offline   Reply With Quote
Old 07-13-2014, 12:19 PM   #25
noreen&sal's Avatar
1981 27' Excella II
Ours broke in Jan. we got in touch with John Burkey. His e-mail address is j.boxmaker@scbglobal.net. If you don't get a response PM him. Noreen
Sal & Nora
AIR 42483
TAC N.J. 17
WBCCI 24740
Old 07-14-2014, 09:51 AM   #26
de NO1PC
JimAspinwall's Avatar
2004 30' Classic
1988 29' Excella
Campbell , California
FYI - none of the available handle/lock replacements fit or seemed suitable for our 88 Excella, of which the problem was NOT the handle itself but the two 90 degree tabs on the slider plate inside the mechanism - the ones the tangs on the handle contact and slide against to pull the mechanism/bolt back.
My fix, as a quicker/easier option than having two new tabs fabricated and welded onto the plate, was to screw on two 1/4" metal standoff blocks onto the plate where the tabs were, countersinking a flat head screw on the backside of the plate. The handle tangs have adequate contact area to pull on the standoffs and shift the plate/mechanism freely. I dare saw the standoffs probably aren't going to bend or break off before the tangs on the handle do, for which there is no fitting replacement, close, but not usable.
I may have pictures someplace.
Enjoy the ride! Best 73!
de Jim, NO1PC
JimAspinwall is offline   Reply With Quote
Old 07-14-2014, 12:24 PM   #27
1981 31' Excella II
New Market , Alabama
Here is a thread where a guy made a new plate with the tabs on it. I think he did a real good job with it.
http://www.airforums.com/forums/f453...ck-122041.html
Perry
Old 07-21-2014, 06:12 AM   #28
Full-timer
nickglase's Avatar
new york , New York
Although I'd highly recommend John's handles (they look superior), I ended up buying interior and exterior hardware from the OEM manufacturer, TriMark. These parts are discontinued but many of them are still available for purchase via ebay.
These fit my 1988 345 motor home:
Trimark Door Handle And Lock Assembly 11298-35-RH (interior side lock and latch)
TriMark series 030-0450 / part number is: 11812-37 (exterior latch)
1964 Vespa GS
Old 07-21-2014, 06:37 AM   #29
1981 31' Excella II
Nickglase, it sounds like you replaced the complete door lock assembly with another brand? I don't know when they stopped putting Keeler Brass Door locks on Airstreams but if yours came with a Trimark Door Lock then we are talking about a different animal.
Perry
Old 07-28-2014, 08:57 AM   #30
Full-timer
nickglase's Avatar
new york , New York
Please note that the TriMark handles were original equipment on classic motor homes and not on many trailers.
1964 Vespa GS
Old 07-29-2014, 08:58 AM   #31
Eden , Utah
How much are these handles?
Old 08-05-2014, 09:12 AM   #32
1988 34' Excella
McDonough , Georgia
Do you have any suggestions for screen door replacement latches, We have an 88 Excella 1000 and the screen door has no hardware on it, just screw holes where previous latches might have been. ODM wants $22 per latch and it's kinda difficult to visualize from the pictures exactly what will fit. Thank You Newbies
Newbies is offline   Reply With Quote
Old 08-30-2014, 10:09 AM   #33
Eden , Utah
How can you get in contact with this guy? I have tried but no reply.
Old 12-13-2015, 06:56 PM   #34
1982 34' Limited
Buda , Texas
I could use a door handle for my 82 limited
TA
Scoeman is offline   Reply With Quote
1970-1977 Main Door Lock gvanman Doors & Locks 69 09-10-2021 01:02 PM
How does the main-door hold-back work? monocoque Exterior Storage Compartments & Access Doors 3 03-20-2008 03:55 PM
main door hinge technautica Doors & Locks 0 09-17-2004 05:34 PM
Main door problems Silvertwinkie Our Community 8 03-02-2003 11:46 PM
1965 Main Door buckmaster 1965 - 1969 Globetrotter 0 10-19-2002 07:47 PM
