Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 08-23-2008, 04:02 PM   #1
city , N/A
Send a message via AIM to cooney Send a message via Yahoo to cooney
Winegard Antenna for FM Radio
Greetings:
We have a Winegard power antenna in our 2008 Safari, but no television (by choice). What I would like to do is use the antenna for FM, as we are often far from stations. Has anyone had any experience with such things? Or, ideas? Plus, the radio (which is the standard issue, not the upgrade) has a wire which can be connected to a "power antenna" of 0.1 amp; any experiences with this?
Thanks...... JC
cooney is offline   Reply With Quote
Old 08-23-2008, 09:38 PM   #2
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
I hook our batwing antenna to our Grundig radio and it works great. You need to have the amplifier button turned on.
Tom
tlavergne is offline   Reply With Quote
Old 08-24-2008, 04:47 AM   #3
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
The "power antenna" wire on the radio is a source of (radio) switch controlled power to raise and lower a motorized antenna. Unless you like fireworks of the 12 volt-kind, best leave that wire alone!
If you have an old 75 ohm transformer ordinarily used to match coax to the screw terminals on a TV antenna, you can use that to match the impedance of your antenna to the radio.
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 10-12-2008, 12:15 PM   #4
city , N/A
Not worth the Effort
Greetings All...
I finally tried the above, which is a 75ohm impedence connection to coax, and hooked to the Winegard. The reception is almost exactly the same as with the built-in antenna, and of course you give up entirely the AM reception. So it's not worth the effort.
Besides, who wants to listen to radio these days? Actually, I do pay attention to the news, rather like a mouse watching a cobra...
All the Best... JC
Radio Antenna for 1962 FC smcpheters 1960 - 1963 Flying Cloud 9 03-26-2020 01:29 PM
winegard antenna dhe9 Roof 5 10-16-2008 06:55 AM
Winegard Roadstar Antenna Pfredd Audio, Video & TV 3 08-24-2008 10:57 AM
Bad Cable from Power Amp to Winegard Roof Antenna tntom Audio, Video & TV 3 06-24-2008 08:09 PM
Which Winegard Antenna? tlavergne Audio, Video & TV 20 08-26-2007 04:09 PM
