07-10-2017, 08:28 PM
2012 19' Flying Cloud
Aurora
, Ohio
TV Mount that Tilts
The television mount on our escape pod works well, extending and pivoting to both the dinette and the bed. It does not, however, allow for downward tilt. When we are watching it while in bed, since we are so much lower than the screen, the image and color are distorted. I need to fabricate a piece for the bracket that allows about a 25 degree tilt. Has anyone seen a solution or created one themselves?
07-14-2017, 10:05 AM
2015 25' FB Flying Cloud
Manassas
, Virginia
if you post a picture or two of your current setup it would help answer this question. I am sure there is something available to help you.
07-14-2017, 10:36 AM
2018 19' Flying Cloud
Newport
The mount that has been used in the 19' the past few years allows for downward tilt. Close to where it attaches to the TV is a pin with a ring through it. Pulling this pin out allows the TV to tilt. If your mount doesn't have this feature you could probably get the current model mount from Airstream.
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
07-14-2017, 11:15 AM
Tampa
There's got to be a mount that tilts.
Look for "Vesa mounts", That's the standard that all modern TVs are drilled for.
07-15-2017, 12:34 PM
BradT
2007 27' Safari FB SE
Milton
, Georgia
I use a Sanus tv mount that swings out from the wall, rotates, and tilts.
When towing, I have two bungee cords that hold it firmly against the wall. Best Buy and other places have them. It comes with a 2 link extension arm so it can have a very wide range of motion. I did not need the wide range and just used one link of the arm. It is sturdier w just one link.
http://www.bestbuy.com/site/sanus-fu...?skuId=8327697
07-15-2017, 04:13 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
When searching for tilting TV mounts, look for "Full Articulating." I researched all of them looking for a tilting mount for my Camco Wave 8 Heater and found several good ones. Even some that would swing 180 degrees and tilt. I wanted to heat both ends of the trailer with one heater.
guskmg
07-15-2017, 06:27 PM
2005 30' Classic
Burlington
, Ontario
There certainly are ones available that tilt as well as swing.
I recently bought one from Costco for our bedroom at home.
I have a smallish home gym set up in an L shaped extension off ur master bedroom and the tv swings around to either area - but it can also be swung vertically and locked into position as well as swinging horizontally.
This was Costco in Canada , so may be different than what you can get from Costco in the US - but if anything, you likely have more choices that us!
It was inexpensive yet very sturdy.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
07-15-2017, 07:01 PM
2022 25' Flying Cloud
NCR
, Ontario
most mounts tilt a bit
often the nylon bearing is VERY stiff.
i suggest that you take it off the wall, dismount the LCD tv and look at it is bright light.
then you can see which parts move and be able to back off the screw for the nylon tilt
07-16-2017, 09:37 AM
2019 25' Flying Cloud
Sequim
I had great difficulty trying to tilt my tv and thought maybe it did not have that capability. After careful examination I found this pin. It also helped greatly to apply some silicon spray to the bracket.
D2
"Having differences makes a difference"
