11-17-2018, 12:46 PM
2018 27' International
Conroe
Store/use switch not working
I just replaced my Group 24 Interstates with lithium batteries and added a battery disconnect switch. I also replaced the stock converter with a Progressive Dynamics 9160L for lithium batteries, as recommended by Battle Born.
Once I completed my installation and powered up the trailer, the store/use switch does not work either when plugged into shore power or disconnected from shore power. The switch will not click in either direction and the light on the panel is not illuminated.
My batteries are fully charged and everything in the trailer has power except the store/use switch. It appears this switch is stuck in the use mode. After reading other threads on the forum I suspect my problem may be the fuses on the relay switch are blown. have looked for the the relay switch to check the 5 amp fuses but have been unable to it on my 2018 27' International FB. I have looked under the bed, by the inverter, in the 12VDC distribution box to no avail.
Any other ideas where the relay switch might be or why switch is stuck?
Eric
11-17-2018, 01:10 PM
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington
, Ontario
I am only guessing. Mine is on the front wall about 8” off the floor. So check under the bed again In a place that is difficult to see and hard to get to.
11-17-2018, 01:46 PM
2007 22' International CCD
Corona
In our rig, the fuses and use/store relay are mounted under the bed, all the way forward on the interior skin. Takes crawling under the bed to get to it after taking everything out of the storage area. It’s a huge pain to get to, and it’s dark and cramped under there.
11-17-2018, 02:01 PM
Conroe
I removed the entire bed top as I placed my new batteries there. The front right of the trailer has the inverter and the 12VDC distribution box. Nothing else there. See picture attached.
11-17-2018, 03:29 PM
2012 27' Flying Cloud
W
, New England
Odd. In mine - a 2012 27FB Flying Cloud - the relay is located exactly where your new lithiums are. Any chance the relay was removed/disconnected while installing the new batts?
11-17-2018, 04:06 PM
Conroe
The picture you see is exactly what was under the bed. Nothing was removed from under the bed. It seems Airstream moves the relay around in any given model year.
11-18-2018, 11:52 AM
Stream of Consciousness
2014 27' FB International
Snoqualmie
Stupid questions here... Are you on our off of shore power? Do you have the same problem either way?
11-18-2018, 12:07 PM
W
, New England
In the original post it’s mentioned that the problem exists whether on shore power or not.
This is puzzling. Where the heck is the relay? Could someone with the same year/make trailer flip theirs off/on and tell us where the relay sounds like it’s located based on the click?
Alternatively - is there a wiring diagram somewhere?
Dang!
11-18-2018, 01:09 PM
2015 27' Flying Cloud
Newberg
, Oregon
I think you can call customer service at AS and they can take your vin and then tell you where it is. It may take some telephone tag, but they will figure it out.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
11-18-2018, 02:05 PM
Conroe
I have the wiring diagram from my owners manual that shows the relay in the schematic. But the schematic does not show the actual location of the relay. I am going to call Jackson Center on Monday. They are usually quite helpful on these type issues.
Eric
11-18-2018, 09:07 PM
2013 27' FB Classic
flemington
, New Jersey
under the road side bed platform, all the way forward is a small panel with 4 screws. My 2013 27fb classic has inverter , solenoid and misc. wiring in that compartment.
11-19-2018, 10:04 AM
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
The connectors right at my use-store switch we’re corroded, created the same symptom. You couldn’t see it until you pulled the connectors off of the terminals.
11-19-2018, 12:33 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Another stupid question...
Why a relay on the use/store switch...is the actual switch in another location? If so maybe ck the switch.
FWIW...ours is wired directly to the battery.
11-20-2018, 09:50 AM
Conroe
Just to give everyone an update Jackson Center has informed me the relay switch is behind the AC breaker panel. I will give an update once I actually locate it and test it. Thanks for all the input.
Eric
11-20-2018, 03:52 PM
GLCMRANGER - Sue
2016 25' International
Littlestown
, Pennsylvania
When you Identify the Switch Relay, there will be 2 5amp fuses on the top. I bet you blew one of the fuses when you were reconnecting your batteries...... it happened to me.
11-27-2018, 03:04 PM
Conroe
I finally located the use/store relay on my Airstream. It is actually attached to the back of the AC panel where the converter is located. I checked all the connections and it appears the red wire (power wire to the switch) appeared to be a little loose. I tightened it up and the use/store switch works perfectly.
11-27-2018, 03:28 PM
W
, New England
Congrats!!
11-28-2018, 07:54 PM
Snoqualmie
I have the same model AS as you do. Can you help me understand where the AC panel is.
Thank you... Dana
11-28-2018, 08:31 PM
Conroe
The AC panel is located at the bottom of the pantry cabinet. There is a black face plate covering the circuit breakers.
