01-06-2008, 07:02 AM
#21
1977 Argosy Minuet 6.0 Metre
Colorado Springs
Originally Posted by trailerpup
I have a 2007 Bambi CCD 16ft. There is a Parrallax 7355 under the bed and under the dinnette there is something marked as WFCO and it looks like some kind of converter/charger, too.
If anyone wants to give a quick schooling on what the 2 different (the parrallax and the WFCO) units "do" - it would be much appreciated.
Thanks.
If you are able to snap a couple of photos and post them here it may be helpful.
Royce (K0RKK) 146.460 simplex
Web page https://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
01-06-2008, 09:01 AM
#22
More than one rivet loose
Los Alamos
, New Mexico
A couple of weeks ago, somehow the 110v over the kitchen counter got shorted out. I could see that the wire coming through the aluminum inner wall had rubbed and cut where the grommet was not seated properly.
I fixed the wire and the grommet. Now, the lights dim when the heater kicks on, the battery has charging problems, etc. I ordered a 7355 R/U lower replacement unit for the Parrallax under the bed. I am hoping this will do the job.
Thanks.
This should have all been covered under warrenty. Send your bills to the factory and get re-imbursed.
Michelle TAC MT-0
Sarah, Snowball
01-06-2008, 09:23 AM
#23
2019 19' Flying Cloud
2006 16' International CCD
Front Range
, CO
I will get a couple pictures going here. In the meantime I started a new thread. Thanks.
01-06-2008, 09:25 AM
#24
Front Range
, CO
Yeah I am going to do that. I have documented the wiring. In the meantime I am in the middle of nowhere. I am having a 7355 lower unit shipped in.
01-08-2008, 11:59 AM
#25
1972 27' Overlander
hartsville
, Tennessee
Hello. I am new to the forums.I have a '72 Overlander and I am in the process of total renovation.I have gutted the whole thing and I'm starting from the shell and moving foward. My question is this: My family and I will not be doing any boondocking so I am going straight electic ( no gas ). Can anyone tell me what type of converter I need to look at? Thanks, Bob
01-08-2008, 03:29 PM
#26
Naples
Hi Bob....and welcome.
You should get in touch with Randy at www.bestconverter.co , as he is the resident converter guru. ...and a member here as well.
lewster
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Parallax charger with temp control
Pacerized |
Batteries, Univolts, Converters & Inverters |
2 |
04-21-2007 06:16 PM |
Intellipower-- 45 or 60 amp?
Foureagles |
5 |
03-05-2007 09:56 AM |
Intellipower wiring
Safari64 |
Electrical - Systems, Generators, Batteries & Solar |
7 |
09-23-2006 11:32 PM |
Intellipower in and tested…
Buttercup |
16 |
06-27-2005 03:35 PM |
Intellipower Ground(s)
Over59 |
15 |
06-16-2005 09:22 PM |
