02-10-2012, 07:15 AM
1964 17' Bambi II
Schererville
, Indiana
Does a converter need venting?
My husband is doing the electric in the Bambi II and insists that the converter needs venting (we got this converter) Inteli-Power 4045
It is being installed under the street side gaucho along with the water tank, AGM battery, and water pump. I don't want to make my cabinetry with a vent in the front of the gaucho, so we're not agreeing on this one. I would have to change up my plans from one continuous bench all the way to the front (I'm planning on a dinette) to splitting them up to vent the side of the gaucho. Is it really necessary? My '86 isn't vented at the univolt. Neither was my '76 I used to have. It's not like it's a refrigerator that it's inside or anything, right? Wrong?
Comments welcome!
Becky
1964 Bambi II
1988 Avion 32S
02-10-2012, 07:27 AM
1974 Argosy 20
Kooskia
, Idaho
In my opinion, no vent will be needed for the converter/charger. Yes, they do produce a small amount of heat, but not enough so some separate vent is needed considering the space under the gaucho. They have a fan built in for cooling and I doubt that the heat they produce would be too much for the space you mention.
02-10-2012, 07:30 AM
1964 26' Overlander
Richmond
, Virginia
When you take the cover off the inteli-power, there is a fan there. Additionally, as your battery is charged or discharged, it's going to produce heat. Normally you don't want to completely enclose the area. However, I would venture to say that the water tank itself might provide a large enough "heat sink" though in reverse, to keep that area cool - if there is water in it.
The other option I would suggest is instead of having one ugly louvered vent, you could add a slot near the top. This could be a 1/4" routed slot in the face, or 2 on the side. Just a 1/4 Router with a straight edge. Tape both sides of the ply before you cut to reduce splintering. This would allow hotter air to escape, and there may be enough area underneath for cooler air to be drawn in. My experience is the intellipower's fan moves a very small amount of air over a heat sink, so you probably don't need a large vented area. You could always wait to see if it overheats and shuts down on you? (but I wouldn't recommend that)
02-10-2012, 07:33 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Becky,
This about all thats needed.
When the access door is closed the cooling fan will bloe thru a screen in the enclosure.
02-10-2012, 07:36 AM
1981 31' Excella II
New Market
, Alabama
You need some degree of circulation for cooling. If the unit does not get enough cooling it won't work correctly. According to the instructions, it won't put out much current if there it not enough ventilation. You can try it with no ventilation and see what happens. Worst case if you will need to add a small computer fan to circulate air. Try not to make the compartment air tight. The original coucho has some ventilation back there. You should be able to hind the vents. The vents don't have to be on the front where they can be seen.
Perry
02-10-2012, 08:19 AM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
They already have a small computer fan built onto the heat sink. As long as you have some space around it for circulation, you should be fine.
Just how tightly were you planning on sealing up the gaucho, anyway? On mine, there are plenty of small gaps around it that allow circulation.
Vaughan
02-10-2012, 08:33 AM
Maniacal Engineer
Lopez Island
I put our in the rear dinette base in the Tin Pickle. This is basically sealed with no air circulation, but it has several cubic feet of space. Last year our batteries started giving up the ghost, and needed a lot of charging after boon docking (before solar), and this compartment would get very warm. I added a fan to circulate air with the rest of the trailer, and this won't reoccur.
The inverter is in the same area; both devices have cooling fans, so some air circulation is a good idea. Note that if air can enter the area low and leave high, the heat will automatically provide that circulation.
- Bart
02-10-2012, 09:15 AM
1964 17' Bambi II
Schererville
, Indiana
That was my point to my DH. The space will be pretty full of stuff, though. I'm planning on making doors on the front that drop down--air would absolutely be able to get in the sides of the doors. The top of the gaucho will have plywood & cushions on it, so not so much there. I guess I might just have to split the long ss gaucho into two (dinette seat separate) so I can put a vent on the side. I just don't want a vent on the front--I'd hate it every time I saw it! Or, if I kept it as one long bench, if you will, would a vent at the dinette be too far away? The distance away from the converter would only be about 3-4 ft (the entire length of the trailer inside is only 14')
Becky
1964 Bambi II
1988 Avion 32S
02-10-2012, 09:33 AM
2002 25' Safari
Dewey
The model you ave (4045) is a wall mount unit according to the PD site. The only stipulation they state is that it should not be mounted in a zero clearance area. If there is room for the air to circulate, it should not be a problem.
Another issue is the battery being in the same area. AGM batteries are required by RV standards to be vented to the outside of the trailer. They are sealed units but can vent if overcharged or overheated.
Richard
02-10-2012, 11:22 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
MISSED that Richard
Very good point, battery definitely should be vented.
02-10-2012, 11:35 AM
1964 17' Bambi II
Schererville
, Indiana
Are you kidding me?! I swear I heard Colin Hyde on the VAP singing the praises of the AGM & how they don't need to be vented!! Now THAT throws a huge monkey wrench in everything!!!!!!! I eliminated the battery box to the outside & put my electrical input there, since I didn't need a battery box, since the battery could go under the gaucho. I'm fairly positive he said it could be put anywhere.
Becky
1964 Bambi II
1988 Avion 32S
02-10-2012, 11:42 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
02-10-2012, 02:15 PM
1964 17' Bambi II
Schererville
, Indiana
I went back & listened to the VAP #13 regarding the battery. Colin Hyde, who has worked on AS trailers for many years, says the AGM's don't need to be vented to the outside. I'm going to give the battery enough room surrounding it, as the manual says, but will not be venting to the outside. The manual doesn't say they need to be vented to the outside. It says NOT to put them in a sealed box, and have adequate ventilation. I don't think my trailer will be that tightly sealed, but I will put a vent on the side of the gaucho (which I have come to terms with already). Thanks for the link to the manual, Robert.
Becky
1964 Bambi II
1988 Avion 32S
02-10-2012, 02:37 PM
Wise Elder
2010 30' Classic
South of the river
Hi Becky.
You're both right. The converter gives off heat. They're typically just under 90% efficient at full load which means that the other 10% makes heat, so you'll have around 50 watts of unwanted heat coming off that thing when it's running at full output. The heat has to go somewhere. If you enclose it under the gaucho it will be conducted away through cabinetry and the gaucho and floor. The question is how much the temperature will rise in the enclosed area when this occurs.
There really isn't any way to find out except to try it and measure. If it's more than a 20 degree rise, you should probably add some ventilation.
There are two sides to this problem. One is heat. The AGMs give off heat while they're being charged, about as much as the converter will (typically around 1 to 2 watts per amp of charging current).
The other side is that in the event of overcharging the AGMs will vent hydrogen. The conservative recommendation is to provide enough venting to dissipate the hydrogen, which would mean that they have to be vented the same way as a flooded battery -- about 2 square inches per battery of ventilation to the exterior of the trailer and sealed off from the interior of the trailer.
But many people install AGMs without those precautions.
02-10-2012, 03:10 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Becky,
AGM=absorbed glass mat+acid
POI...a misconception about AGM's, they are not a "flooded cell" battery, but the acid is still there and the AGM can still be dangerous. You would be hard-pressed to find a manufacturer that installs the batt's inside the living area.
By all means....be safe.
02-10-2012, 05:50 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
you don't need much of a vent. didn't the older trailers us a small rubber hose that went from the top of the battery box to the exterior? i'd still use a battery box because while rare, a leaky or exploded battery would male quite a mess.
Ricky
02-10-2012, 06:02 PM
Maniacal Engineer
Lopez Island
Hydrogen is not an issue - it will escape any battery box save for a Mylar bag very quickly.... if something does go wrong and the converter starts trying to boil the batteries, you really don't want the resulting fumes, etc. in your living space. I made a battery box out of aluminum, and vented it straight down under the trailer via a piece of 1 1/2" ABS pipe which sticks out perhaps 1/2" out of the bellypan. Simple, done in 20 minutes and no worries about waking up in a sulfur trioxide fog.
Vented battery boxes are readily available.
- Bart
02-10-2012, 06:31 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Well I guess we found one.
02-10-2012, 07:22 PM
1964 17' Bambi II
Schererville
, Indiana
Thanks for all the imput! Bart's idea sound interesting. I'll have to have a heated debate with my DH about this!
Becky
1964 Bambi II
1988 Avion 32S
02-10-2012, 08:21 PM
1976 Argosy 24
now being enjoyed by Heath and Mary in
, Vermont
Becky,
I think it depends on what expert you talk to. For what the Lifeline distributor in Toronto told me, in person, read post #275 here:
http://www.airforums.com/forums/f227...tml#post394434
In the end I chose another brand of AGMs, Odyssey, and had them installed under my bed, next to the charger and inverter. You can see my set up in post #649 here:
http://www.airforums.com/forums/f227...tml#post911848
The man that sold me my Webasto diesel furnace, and who was such a sterling help to me during my remodel, sold and installed the batteries. I asked Randall whether they needed to be vented. He, too, said no.
That’s from two experts, working with AGM batteries everyday.
I would say that the warning that appears in the Lifeline material above is the kind of boilerplate that every manufacture of pretty much everything has to use these days, no matter how remote the possibility of a problem.
On the other hand, safety codes are for our safety. There IS a marine world code stating that batteries of all types have to be vented.
I might just poke a little hole to the outside and put a small vent in the compartment next summer. But I don’t think building a box, like for regular wet batteries, is needed.
Sergei
