Old 08-24-2010, 02:15 PM   #1
1978 28' Ambassador
Long Island , New York
Can Anyone Identify this?
I recently purchased a 1978 Airstream Ambassador (Rear Bath and Double bed).
It needs work although the floors feel mostly solid (even in the corners). Some day I may opt for a complete restoration. For now however, I would simply like to get the camper “camping ready” so that I can enjoy it with my wife and kids - while they are still young and find it cool to go camping with their parents.
My plan is fix/replace the other items in between our weekend excursions.
I am nowhere near as mechanically inclined as most on this board - In fact I am totally blown away by some of the projects undertaken by some of the members and the remarkable results. I can however follow directions and use a screw driver.. And I know my limits.
The first thing I decided to tackle was the electrical.
The AC power works fine. I was baffled as to why the DC power did not work until I read the forums and learned about the “Univolt”. Well, mine is missing.
In addition, only one of my batteries seem to be wired to the fuse box right now, although the wires for the other battery are already run.
I read that most users replace their univolts with an Inteli-Power unit anyway, so I am hoping that would be the solution for me. I have ordered an Inteli-Power unit (9260).
I have included some pictures of my current fuse panel. If you look at the pictures you will notice two black holders. I have no idea what those are or what if anything may be missing from them.
I do not yet have a manual, but I have ordered one from Airstreams.
I also do not see wires that connected from the old univolt to the fuse panel. Did it connect to the fuse panel?
Can anyone identify the rubber holders and tell me what if anything is missing?
Also, when I receive the Inteli-Power unit, how do I tie it into the fuse box?
I will have many questions as time goes by, so please bear with me.. and thanks.
ID:	109257   Click image for larger version
dnssandbox is offline   Reply With Quote
Old 08-24-2010, 02:18 PM   #2
x
XXXX , XXXX
They are inline fuse holder for the newer mini fuses like in modern cars and trailers. I can not tell what amp fuse to install there. Trace wires and see what they run
wasagachris is offline   Reply With Quote
Old 08-24-2010, 03:01 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Where do the large red and black wires in the upper left corner go? They look like the large wires from the Univolt to the batteries to me. You can see photos of my Inteli-Power install at http://www.airforums.com/forums/f449...0-a-57567.html.
The 9260 should be an excellent choice for you.
Vaughan
vswingfield is offline   Reply With Quote
Old 08-24-2010, 03:06 PM   #4
1978 28' Ambassador
Wow.. That was a quick response wasagachris. Thanks.
They don't seem to run anything.
From what I can see both wires are connected to the red battery cable. Then one of them goes to the left side of the "right fuse block" and the other wire runs to the right side of the "right fuse block". in short, they seem to be for the battery. Does that sound right?
Are they standard on the 1978 Ambassador. If so does anyone know what fuse they take or what I can replace them with?
Old 08-24-2010, 03:13 PM   #5
1978 28' Ambassador
Vaughan: thanks for the link. Much appreciated. Do you have any other pictures that show the connections?
The red and black wires are coming from the battery.
I have attached a few more pictures, hopefully they tell the whole story.
Edit:
Mmm. Not sure why I am having issues uploading the additional pictures. I will reboot and try again.
Old 08-24-2010, 03:35 PM   #6
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay , Oklahoma
Hello, and welcome!
To answer at least one question, no the rubber socket fuse holders are not from '78. As mentioned above, they hold the more modern blade type fuses and have been added. The glass fuses are stock.
The rubber inline holders appear to be attached to the supply side of the fuse block. Maybe meaning they may connect the battery to the fuse panel for distribution to the rest of the trailer. I would start with 15 amp fuses in both, a charged battery, and see what comes to life.
Jeff & Cindy
jdalrymple is offline   Reply With Quote
Old 08-24-2010, 04:02 PM   #7
1978 28' Ambassador
Ok.. Here are the additional pictures.
note: the Inteli-power is not in the unit - the univolt box is empty
ID:	109267   Click image for larger version
Old 08-24-2010, 04:40 PM   #8
1977 31' Excella 500
plano , Texas
I would stop at a 20amp fuse as the wire looks like 12AWG. 12AWG is only rated for 20 amps.
tschat is offline   Reply With Quote
Old 08-24-2010, 05:18 PM   #9
1978 28' Ambassador
Jeff & Cindy: Thanks. I put 2 - 15 amp fuses in along with a battery and all the lights and light switches worked.
All except for the "Central Control Panel" - there were no lights on it. Could it be because I do not have a univolt or the Inteli-Power installed?
Thanks to everyone for all the assistance. It is invaluable. It is quite a relief to be making progress with this.
Old 08-24-2010, 05:21 PM   #10
Mexray's Avatar
1978 28' Ambassador
Morada , California
We have the same model and year trailer as you....however, the fuse panel in ours looks like the one shown on this thread...http://www.airforums.com/forums/f449...0-a-57567.html.
The fuse panel in your AS looks like an older type...perhaps something installed by a previous owner?
If it was me, I'd get a new fuse panel, like the type sold by several of the popular vintage trailer parts suppliers, and start over...
Older fuse panels with wiring that looks like a 'birds nest' will only give you headaches in the future - questionable connections with tape around them just don't get it...
You can unhook the battery cables at the batteries so you don't have to worry about any 'sparks'...
Then carefully remove each wire and label it's function, etc - use a digital volt-ohm meter to help with this process...
You can get a couple of separate insulated stand-offs to hook the batteries cables to, then jump to the new fuse panel if need be...
Try to work in an organized manner so it's easier to trace wires at any future date, and labels will help, with a chart attached nearby for reference also helps...
Also the later fuse panels use the plastic two-prong fuses that tend to keep their connection better than the old glass tube types - and it's usually easier to see a blown fuse with the newer types...
You can see some of the things we've done with our AS in the Ambassador section of the Forms here...as well as others mods...
We like our Ambassador a lot, and just got back from a camping trip up into the Sierra Nevada Mt's - the only shortcoming we don't like is the small capacity of the 'Main' (black) and 'Aux' (gray) holding tanks...got to keep the old 'Blue Boy' external dump tank handy!
Good luck with your 'new' toy...
BTW, our serial no. is: I28T8S1291 so you can compare with yours...
Ray
Ray & Pat; Morada, CA
Old 08-24-2010, 06:10 PM   #11
1978 28' Ambassador
Thanks for the suggestion Ray. I will try to locate a new fuse box.
Old 08-24-2010, 07:43 PM   #12
jdalrymple's Avatar
Jay , Oklahoma
Take a look at BestConverter - Converters, Inverters, Electrical Supplies, Electronics, nice folks and have lots of options.
If you have a good battery a univolt, or other power supply, shouldn't make any difference. The power supply simply converts 120 AC to 12 DC to power the lights and appliances, and charge the battery, in your trailer when shore power is available.
I would check the fuses and make sure they are passing power. I have been fooled just looking. If a multi-meter is over whelming, just pick up a 12 volt test light from an auto parts store. I prefer a light to a meter when doing simple tests. They are only good for 12 volt DC, but simple. If it lights it works. No light, no work.
Good Luck!
Jeff
Jeff & Cindy
Old 08-24-2010, 08:05 PM   #13
1978 28' Ambassador
Jeff: Are you saying that I should have power at the Central Control Panel even without the univolt? Bummer.
I will have to pick up a test light in the morning to check.
Thanks for the help and suggestion.
Old 08-25-2010, 03:32 PM   #14
1978 28' Ambassador
Well, I figured out why the Central Control Panel was not working.
I tested the fuses and they were all okay. So, I decided to work backwards. I noticed a white/cream colored cable (looks like and old round phone line) coming out of the right side of the Control panel above the stove. I traced it and found that the cable had been cut and tucked up above they stove.
Why would anyone do that? I just don't get it.
I am still awaiting my manuals, but does anyone know where I might look to find the other end.
I did a cursory below the stove but did not see it.
There was a similar cable below the stove, but that wire looked to braided wires within the shield.
I feel like I am solving a giant puzzle here.
Old 08-25-2010, 04:13 PM   #15
Splitrock's Avatar
Sioux Falls , South Dakota
That's how I felt when I was working on my 7-way plug and the break away switch.
Gary
Click on the link to see a picture of the Sioux River falls near my home.
https://visitsiouxfalls.com/assets/i...uxfalls-og.jpg
Eastern South Dakota is very pretty with hills, rivers, and trees.
Splitrock is offline   Reply With Quote
Old 08-25-2010, 04:21 PM   #16
Coastalview's Avatar
2002 27' Safari
Carmel-by-the-Sea , California
Images: 14
Send a message via AIM to Coastalview Send a message via Yahoo to Coastalview
I'll take a look in my manual to give you an idea where to search for the other end of that cut cable. As you can see us 78 Abassador 28's stick together when in need. I have the floor plan like yours with the fuse panel up front with the two batteries and would be your univolt location. My unit hasn't been hacked up so things appear to be in a orderly fashion.
Jeff
AIR: 649
TAC: CA-40
Northern California Airstreamers
Coastalview is offline   Reply With Quote
Old 08-25-2010, 04:43 PM   #17
1978 28' Ambassador
Thanks a Million Jeff.. It is great to have shoulders to lean on at times like these.
Old 08-25-2010, 04:57 PM   #18
Mexray's Avatar
1978 28' Ambassador
Morada , California
Here's a good fuse panel to check out - they even have a wiring diagram to take a gander at...
12V RV Fuse Box
sounds like the PO had a problem with the central control panel, and just cut the wires to 'cure' the problem...some of the LED indicators on our panel are intermittent, but it's still usable....
Ray
Old 08-25-2010, 05:50 PM   #19
1978 28' Ambassador
Thanks for the link Mexray. The wiring diagram clears up a lot for me.
Old 08-25-2010, 07:25 PM   #20
stephenh2's Avatar
Tyler , Texas
Not sure if the '78 is same as my '74, but if the Univolt is gone then probably the shunt for the voltmeter in the control panel is gone. The PO probably didn't bother to go to the effort to get the meters working after removing the Univolt.
I also recommend Bestconverters. Bought my Intelipower from them and a new fuse block at the same time. I don't have my control panel working either, but plan on going back and working on it at a later time.
Welcome to the forums,
Stephen
Home again in Tyler, Texas
The Rose City
stephenh2 is offline   Reply With Quote
Can someone identify this for us please? T&E10876 Fresh Water Systems 3 03-24-2010 11:29 AM
Can anyone identify these? bullydogsmom General Interior Topics 7 04-06-2009 05:20 AM
Please Identify chaimemet Vintage Kin 12 12-08-2008 08:49 AM
Help identify cosmotini Off Topic Forum 17 01-04-2008 11:22 PM
Can Anyone Identify? rhoward Airstream Trailer Forums 12 12-11-2007 06:42 AM
