I believe in reading info on boondocker and powermax converters/chargers the difference between 3 and 4 stage is the 4th stage will after a certain time frame and no load, greater than like 2 amps, the charger will increase volts from the float 13.2 to 14.6 with no or very low amps to cause the liquid to flow. This is something short of a battery boil.
If you store your RV for long periods with charger plugged in it might be better for the batteries. Not sure what a long time is, one month or 9 months. best advise.. USE it, the rv that is.
during winter i keep my diesel truck with 2 large batteries hooked up to a small battery tender i got at harbor freight. It puts out like 14.7 volts adn drops to 13.4 it seem to increase voltage every so often as well.. I will unplug it after a month or so and let it sit for a week and then plug back in.
Originally Posted by mcaslaon4449
We have a 25' FC which we added a 4 stage converter. We will be purchasing a 2018 25' International which we are told has a 3 stage converter. Are they similar enough or would you suggest I swap them out? Thank you.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691,
Piedmont Airstream Club, Unit #161, Region #3
