Old 04-09-2014, 01:48 PM   #1
mike28's Avatar
2005 28' Safari S/O
Lakeland , Florida
Solar trickle charge
I need advice on what I need to purchase to maintain my batteries by solar power. I have two Interstate deep cycle batteries in a parallel configuration. I only need to keep batteries up while in storage. I have contacted several sources with differing suggestions on wattage.
mike28 is offline   Reply With Quote
Old 04-09-2014, 02:36 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
AM Solar seems to have their act together and should be able to help you. Or, PM Lewster.
Larry
lsbrodsky is offline   Reply With Quote
Old 04-09-2014, 02:39 PM   #3
Mike91208's Avatar
2009 27' FB International
LA LA Land... , California
This worked great for keeping the batteries topped off. (I've since sold it as I installed three solar panels on the roof.)
Amazon.com: BatteryMINDer Solar Charging System - 12 Volt, 15 Watt Panel, Model# SCC-015: Automotive
Mike91208 is offline   Reply With Quote
Old 04-10-2014, 05:16 PM   #4
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
A hundred and eighty bucks is a pretty high ticket for a 15 watt panel and a charge controller. You'd have to have a lot of blinky-lights on it to convince me it was a good deal.
This one is cheaper with more power - I have no knowledge or interest other than it popped up on eBay: High Efficiency 30W Mono Crystalline Solar Panel Charger Kit for 12V Battery | eBay
Old 04-10-2014, 05:35 PM   #5
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
I bought two 15w panels at Harbor Freight 5 years ago for my trailers - cheep and still working great! Did not come with controller - just hook direct - they put out 12v and are made purpose built for this - they still carry them, friend bought two this year.
Silver Hawk is offline   Reply With Quote
Old 04-10-2014, 07:19 PM   #6
Naples , Florida
I have used the BatteryMinder systems for very small maintenance applications, and they have performed admirable…..even with a 15 watt panel. The strength is in the charge controller, which is a true 3-stage unit, is adjustable for battery type AND has temperature compensation.
While the 30 watt system from Amazon is higher power, the specifications of the controller are a total unknown, as no specifications are provided in the listing. I would go with the known quantity from BatteryMinder over the 'deal' every time.
lewster
Old 04-13-2014, 10:12 PM   #7
Kyle401's Avatar
1969 27' Overlander
SW , Missouri
For about the same price as the battery minder you could get a basic 100W kit. I would think that would be a better match power wise to your two batteries.
Kyle401 is offline   Reply With Quote
Old 04-13-2014, 11:25 PM   #8
drboyd's Avatar
1978 25' Tradewind
Old 04-15-2014, 10:31 AM   #9
dznf0g's Avatar
Oswego , Illinois
I bought a 15 watt several years ago, but I didn't pay anything close to $160. I can't remember where I got it....I thought Northern Tool, but I don't see it on their website. I paid something like $70 on sale. 15 watts does work as a trickle charger for me. It puts out about 750 - 800mA in full sun and about 500mA in cloudy weather.
I always find my batts at 98 - 100% (per Trimetric monitor) when I go to pick up the AS. That's when I have stored it with the cutoff switch in the on position (draw = about 225mA).
Let me add: the 750 - 800mA is with the draw in place...so the panel is actually putting out over 700mA in clouds and around 1A in direct sun. The lower numbers should be used for overnight battery recovery figures.
-Rich-
Old 04-17-2014, 10:00 AM   #10
2018 23' Flying Cloud
Eagle Creek , OR
Send a message via Skype™ to almcate
The Renology Kit that Kyle mentions sounds very attractive and I'm wondering how difficult it might be to use as a stand-alone portable rather than a roof mount. Living (and moving) full-time in our 27FB does limit my access to tools, ability to access roof, and my mechanical and electrical aptitudes are similarly challenged.
Looking at the wiring diagram from the Amazon link, appears the panel would directly connect to the batteries with controller mounted inside the battery box or attached to the panel. Does anybody make a case/frame for angled position to use/transport the panel...assume damage could be an issue if bounced around.
I think I read someplace that the 2010 Internationals are prewired for solar, so for a wiring weenie maybe an installed roof mount wouldn't be that much more expensive?
Thanks, Al
Question: better to be a successful pessimist or a failed optimist?
Al & Robin
2018 Airstream 23FB Flying Cloud
2015 F150 XLT 3.5L EcoBoost, 4WD
almcate is offline   Reply With Quote
Old 04-17-2014, 09:27 PM   #11
Kyle401's Avatar
1969 27' Overlander
SW , Missouri
There are several 100W folding panels that come pre-wired with a controller. Renogy, Instapark, and Go-Power all offer portables in the 100W range. All these systems come with protection during transport and alligator clips to connect direct to your batteries.
Old 04-18-2014, 08:56 PM   #12
Eagle Creek , OR
Before I pull the trigger on a portable unit, it occurs to me that something that light would be VERY portable. Chaining to a tree probably isn't the answer...anybody have a straightforward trick to make them LESS portable?
Al & Robin
Solar trickle charger.... drboyd Generators & Solar Power 30 10-21-2019 11:23 PM
How many volts in trickle charge line - 1968? BuffaloJoe 1965-1969 Sovereign 13 05-27-2013 09:58 AM
Great deal on Solar Trickle Charger ddruker Generators & Solar Power 1 08-28-2012 06:33 AM
Will mini solar panel trickle charge over winter? woodytwo Land Yacht/Legacy Motorhomes 14 12-19-2011 05:24 AM
Can I Trickle Charge into the 12V Wall Jack? westeagle Electrical - Systems, Generators, Batteries & Solar 5 01-21-2004 03:19 PM
