01-22-2015, 08:18 PM
2015 27' Flying Cloud
maple grove
Small solar to mount on LP tank or battery cover
Has anyone looked into mounting a very small solar on the lp cover or battery cover to trickle charge the battery when in storage
01-22-2015, 11:14 PM
1999 34' Excella
Hillsboro
I have one which charges my dual automatic gate battery. Works great! I have had no issues with 'over charging'... If I recall, it is a 12 watt Solar panel.
Peace and Blessings..
Channing
WBCCI# 30676
01-23-2015, 12:28 AM
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge
Your idea may seem simple but why not just go to the next step and instal a entire system on the roof with the new flexible solar panels and let the system work as is should? Your idea is a old way of looking at a problem that has a new solution.
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
01-23-2015, 06:59 AM
maple grove
Thanks but I believe your definition of the "problem" is different than mine. But thanks for the comment anyway.
01-23-2015, 08:54 AM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Yes, a 12 watt trickle charger that goes to our batteries. Mounted on the LP lid with no problems.
Had to look all over for a good photo, only one I could find on hand that shows it.
Heading over there tonight, so if you're curious about how it's mounted, I can take more photos.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
01-23-2015, 09:26 AM
Vintage Kin
Fort Worth
small solar to mount on lp tank or battery cover
Man, I'm liking that blue/green tow vehicle in the pic. Methane power?
01-23-2015, 03:01 PM
Oswego
In northern climes I'd go 15 watts. With the sun angle, cloudy days, and shorter days in spring and fall, I found, with 15 watts (after wiring losses, etc) and parisitic drains with disconnect switch OFF, that I got about 750mA output to the batteries in FULL sunlight. That's enough to make up for the above climatic issues. If I have 3 fully overcast days in a row, it takes one full sunshine day to return to 100% charge with a 15 watter. All this from observing the Trimetric monitor.
-Rich-
01-23-2015, 05:28 PM
maple grove
Hey bold adventurer, would like to see more pictures
01-23-2015, 06:04 PM
Nomadic
, USA
Boom! Excuse the pollen. Florida.
01-25-2015, 01:28 PM
1965 17' Caravel
Silver Cliff
Solar charge.
I have done it and it works great on my 65 Caravel. Just make sure the polarity is correct. I quickly hooked a solar charger to my 64 Tradewind and the polarity was reversed, it ruined my battery and shorted out my 12 Volt side of the Trailer, now I have to replace the battery and find what all is not working. Be careful and don't hurry as I did.
Don
01-25-2015, 01:29 PM
1965 17' Caravel
Silver Cliff
Also it is good to check if the solar panel has over charge protection.
02-23-2015, 07:26 PM
Nomadic
, USA
After some research and removing mine, I believe now that it is a Sunforce 5W trickle charger based on a sticker on the bottom of it. http://www.amazon.com/gp/product/B00...KAMYV5P3XJPEZV
