Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 07-06-2015, 11:50 AM   #1
2006 25' International CCD
Petaluma , California
portable solar generator has anyone used one?
Looking for a solar powered portable generator instead of my Honda 3000 gas powered generator.
Has anyone bought and used one? I can only find one available at Lowes and it only is 1250 watts for about $1900.
we visit a lot of national parks and they limit your use of generators.
telkxa1 is offline   Reply With Quote
Old 07-06-2015, 12:00 PM   #2
Naples , Florida
All of the so called 'solar generators' are nothing but an AGM battery, solar panel/controller combination and a small inverter.
You can assemble a much more capable system for the same dollar outlay, or possibly less, bug it will NOT replace a fueled generator for things like A/C use.
You can now operate a roof A/C unit from lithium batteries and hybrid inverter (for a limited amount of time), but that requires a significant investment in a comprehensive solar charging system.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
lewster
Old 07-06-2015, 06:30 PM   #3
DuncanK1's Avatar
2015 30' Flying Cloud
Berrien Springs , Michigan
ZAMP do a series of portable solar packages.
Portable Solar for your RV - Zamp Solar
The biggest package at 200 watts is not going to replace the generator, but its a nice way to top up batteries without annoying neighbors.
DuncanK1 is offline   Reply With Quote
Old 07-12-2015, 12:20 AM   #4
2015 25' Flying Cloud
Eugene , Oregon
Solar on a Shoestring
I just purchased a Renogy 100 watt folding solar suitcase to charge my batteries at about 1/2 the price of the Zamp 120 watt system. The two units look about the same, but I have been very happy with my Renogy. My AS sits in a covered storage facility that has no electricity when we are not camping. There is a parasite battery drain from the propane detector while in storage. That and general usage when I'm doing work on my AS prompted me to investigate a cheap way of charging the batteries. On a sunny day, my unfolded suitcase can generate up to 5 amps. However, when overcast, it only generates about 1.3 amps. As such, I tend to go out to my stored AS on sunny days when doing routine maintenance, etc. I use a 15 foot cord made of 10 AWG wire to connect the batteries to the solar panels. I use SAE connectors at both ends for easy setup. These panels might help when dry-camping, but they would have to be out all day in the sun to be helpful. They couldn't be left outside unattended due to possible theft. At $269.00 direct from the manufacturer, I think I found a solution to charging my batteries while in storage.
ID:	242725   Click image for larger version
ltorgy is offline   Reply With Quote
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 03:04 PM
Has Anyone Used 'Bad Dog' Polish? aircooled4 Cleaning, Stripping & Polishing 6 02-03-2011 07:14 PM
Cummins Onan, Has anyone used them? DFord79 Generators & Solar Power 18 11-09-2007 09:50 PM
has anyone used sisal carpeting for the floor? zoeb nj Repairing/Replacing Floor &/or Frame 0 08-31-2005 03:58 PM
has anyone used Gords polish? 3x2x4sp389 Cleaning, Stripping & Polishing 6 04-06-2005 07:18 PM
