Old 05-30-2014, 10:07 AM   #1
light out
the light in the switch for the fridge fan is out. hope the fan is still working. it is in the on position but no light. does anybody know how to replace the light. i am hoping that is all it is.
dsrtgrls is offline   Reply With Quote
Old 05-30-2014, 11:23 AM   #2
i guess as long as the switch still works to turn the fan on and off no problem.
Old 05-30-2014, 12:57 PM   #3
no fan on yet. fuse to fan in back of fridge looked perfect. fingers crossed
Old 05-30-2014, 01:27 PM   #4
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I recently had the light go bad on our fridge but not sure if we have the same make and model. the light on our fridge turns on when opening the door and it is located on the left side of the refrig when looking in. It is covered by a white plastic cover. The cover easily prys off. The light can be bought at an auto shop. Hope this helps.
urnmor is offline   Reply With Quote
Old 05-30-2014, 02:56 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
The light in the switch for the frig fan in our Bambi kept burning out. We replaced the switch 3 times, and it still happened. So we have not replaced it again...the switch (and fan) themselves still work for us. Hope this helps.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 05-30-2014, 04:45 PM   #6
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
So the newer model fridges come with a built in fan somewhere around the cooling fins in the back? I've seen an after market version of that here on the forums somewhere in a thread....
If somebody has a picture of that setup, I'd sure like to see it. Maybe I can buy one from Dometic??
Thanks gang.
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Old 05-30-2014, 05:29 PM   #7
the airstream set up is loud. seek other fans.
Old 05-31-2014, 01:50 PM   #8
bottom line. switch lite is out and switch does not turn on fan. all wires underneath switch are tight. so bad switch only or both fan and switch. to be continued.
Old 06-01-2014, 06:44 AM   #9
urnmor's Avatar
Berlin , Maryland
I am no electrician however is it possible that if the light is bad it breaks the electrical connection to the fan and the switch. I would use a volt meter to see if there is electricity before I would invest in new switch or fan. I am sure others can explain this better then me
Old 06-03-2014, 08:49 AM   #10
Dan@LED4RV's Avatar
Denton , North Carolina
fuse
I can't tell you how many times over the years I have assumed a fuse was good because it looked good. Test it some kind of way. If you don't have a test light or meter, move the fuse to a " Known good " curcuit of the same value, and see if the items on the circuit work. Both the light and fan not working seems odd.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 06-28-2014, 06:28 PM   #11
Smile well well
the dealer fixed the fan/light. it was as you said. the fuse looked good to me. he found that the fuse was no good and ta da. good feed back.
Light or light cover over the door.. help please! harestream Lights - Interior & Exterior 21 06-22-2021 01:07 PM
Scare light and marker light won't work??? shinybean Lights - Interior & Exterior 12 02-12-2007 08:51 PM
"Let there be LIGHT...and there was no light !!!! Randy Wilson Electrical - Systems, Generators, Batteries & Solar 11 11-08-2005 01:00 PM
Can't light furnace pilot light? (again?) MrSalt Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-05-2005 11:52 AM
light globe/light covers David Hall Electrical - Systems, Generators, Batteries & Solar 5 02-18-2004 06:35 AM
