No. Most silicon caulks contain acetic acid which is a no-no on aluminum. If you pop the lense off of one of the fixtures you should see that the hole the wires come through is sealed with goop of some sort (at least they are on mine). This should keep moisture out of the shell wheel letting any trapped moisture escape from the fixture.
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
