11-10-2011, 08:11 AM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
Caution when ordering LED replacements
I can't find the thread where this link was originally posted.
36-LED SMD Warm White Interior Room Dome Door Car Light | eBay
I ordered 26 lights form them and they were delivered without problem, unfortunately while it looks like and 1156 (BA15s) base in the picture, it is really a BA9s base and won't work. I have been unsuccessful finding an adapter to make them work, so will have to return them to China.
I just wanted to give a heads up to anyone looking at this site. If you have another style base, you may be OK.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
11-13-2011, 02:13 PM
1987 32' Excella
Nepean
, Ontario
I ordered my LED lights from Dan at led4rv.com - Dan used to be a repair tech at an Airstream dealer, so he knows some of the "peculiarities" of Airstreams.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
11-13-2011, 02:32 PM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
I was being cheap and it will end up costing me $36 to send the LED's back to China for my refund.
Lesson learned
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
11-13-2011, 03:12 PM
1978 Argosy Minuet 6.0 Metre
Wauwatosa
, Wisconsin
Dan's the man
I bought all mine from LED4RV. Had a problem with a couple of them. Was able to talk to Dan on the phone. USA call. He really knows his stuff.
Princeton
, New Jersey
At this point you are $36.00 ahead and have some lights. Consider hard wiring them in.
2004 Excursion 4x4
11-13-2011, 04:33 PM
2005 25' Classic
Austin
I have had good luck and good support from Dan at led4rv. Pay a little more and get good products and good service.
Dennis
11-13-2011, 04:52 PM
Oswego
Dennis
Ditto, got all mine from Dan. About 10 months later a specific type of bulb, of which I had three, started to fail the individual LEDs. Dan readily acknowledged difficulty with that supplier and he subsequently changed suppliers. Three new bulbs arrived a few days later. Sometimes ya gets what ya pays for......and he's really not that high anyway.
-Rich-
11-13-2011, 04:57 PM
2005 30' Classic
Burlington
, Ontario
I'd have to say that my experience with LED's hasn't been great.
I like the concept and even though we don't spend much time without hookups, like the low power consumption for those times we are on batteries ( we have a Honda gennie now so that isn't too much of a consideration now anyway.)
I installed them in the reading lights at the front and rear of our trailer, but truth to tell, they are not really as bright as I would like. I still have them in place, but am considering putting the halogens back in. I am sure I will if/when any of the LED's fail in service.
I bought them also for the chandelier type fixture over our dining table. Initially the supplier (a US supplier of AS parts) sent me the wrong ones, cool white instead of warm white. It was a bit of a hassle exchanging them as we are in Canada.
When I installed them, they lasted maybe a day and all teh individual LED's started falling off!
I probably should have sent them back yet again, but I was so fed up I just wrote it off and put the automotive bulbs back in!
Initially I had planned on also replacing the fluorescents with LED's but they are darned expensive and we rarely use those lights anyway (I have a thing about ceiling lights -don't like them!) so I won't be doing that after all!
On the plus side, I built a tiny luggage trailer to pull behind our motorcycle on longer trips and have had good luck with LED lights.
I have found in the past that I often have troubles with regular trailer light bulbs (clearance lights stop/turn lights) from burned out bulbs and often corrosion in the sockets.
So when building this trailer, I used LED tail lights that are submersible, intended for boat trailers.
There are no sockets, the LED's are "Potted" in epoxy modules. As well, I soldered and shrink-tubed all the connections - nary a problem in about 5 years use. They draw little current from my motorcycle electrical system and are very bright.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
11-13-2011, 05:38 PM
2022 23' Flying Cloud
2006 28' Safari SE
Gold Beach
, Oregon
I paid the high prices getting mine directly from Airstream online but they work great.
Idmtman
2022 Flying Cloud 23FB (Yalla)
2010 Toyota Tundra 4x4
TAC: ID-1
11-13-2011, 05:44 PM
2008 27' Safari FB SE
Pfafftown
, North Carolina
LED's
Dan at LED4RV was terrific. He helped me choose the correct replacements for my 2008 Safari 27FB. He fixed the one problem I had quickly and with no hassles. I'm happy with his products and outstanding service.
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2022 Ford F350 King Ranch, 6.7 Diesel, 4X4 (Big Red)
WBCCI 3823 - Unit 12 | AIR 48265
11-13-2011, 06:16 PM
2000 25' Excella
Northern
My experience with LED’s in my Airstream is similar to “Wingeezer”, i.e., disappointment. I ordered LED replacements for my puck lights over the front sofa directly from Airstream. They installed nicely, after removing the halogen reflector (which I luckily saved). I converted one to LED, and left the other as halogen for comparison. The color temperature of the two is quite different, as the halogen produces a much “warmer” (yellow) light that looks better in my “classic”, while the LED is a higher temperature light (bluer) that may look better in some of the newer models with aluminum interiors. The quantity of light (lumens) is also greater in the halogen. I intend to convert mine back to halogen. I’d really like more light along the sofa, so alternatively, I thought I might replace the pucks over the beds, move them to up front so that I would have 4 matching lights over the sofa, all halogen.
12-01-2011, 10:06 AM
1999 25' Safari
Denver
Ledshttps://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=330626694966&ssPageNam e=AD
The few trips that we boondocked this year I knew that I wanted to switch all my interior lights to leds, not only to save on battery power but I really like the look. I'm now working on all the outside lights. Here are the links where I purchased all the leds.
Jim D.
AIR # 56543 TAC# CO-10
12-01-2011, 02:55 PM
2008 22' Safari
Oracle
Better than 4 years on mine and still goin strong. Got mine from Superbrite LED's and Dan. I like them a lot. You get what you pay for.
12-10-2011, 11:57 AM
2012 25' Flying Cloud
Eureka
We have a new FC with the LED interior lights, and the aluminum skin interior. I find the LEDs to be way too white hot. I'd guess they are above 6000K. It gives off an eerie electronic look inside that I don't enjoy. Neither does wife.
We have an small table lamp we use with a 3500K bulb and it gives a nice warm yellow tone that goes nice with the yellow leather. I don't know much about these LEDs yet, but I am going to see if they make some in much lower temperature range like our 3500K lamp. We have about 12 of these things in the roof!
Also, some form of "filter" that could be applied over the fixture might work to warm them up.
12-10-2011, 02:44 PM
1999 25' Safari
Denver
The LEDS that I got are called WARM LITE which are real close to the inc bulbs I replaced. So look for warm lite not bright white. I felt like I was in an office Bldg with the other ones.
Jim D.
12-10-2011, 06:52 PM
2012 16' International
2015 25' FB International
Milwaukie
, Oregon
Count us in as ones who HATE the new blue look of the LED lights. Our new AS has them and it gives out a really blue, cold glow at night. Right now we light ours with a table lamp and the lamp from the stove hood. We don't turn on overhead lights unless really needed. We were also wondering about some sort of lens cover to warm the lights up. Think we're just going to give in and order the warm lightbulbs. It's going to cost a small fortune though....grr...
12-10-2011, 07:51 PM
Hollis
, New Hampshire
You may want to take a look at this thread and see if this might work for you
http://www.airforums.com/forums/f447...eds-82876.html
12-10-2011, 07:59 PM
Milwaukie
, Oregon
Originally Posted by reinergirl
Thanks so much for linking to this thread!!! Went to the OP's blog and now am excited to try the "gel method" myself
12-10-2011, 08:05 PM
Hollis
, New Hampshire
You're welcome, I remember thinking at the time that it was a cool idea. Cool enough that I bookmarked it!
12-10-2011, 08:46 PM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
My problem wasn't the color, but the plug on the end of the bulb. Nit was a mini fitting and not the full size 1141. It also included plugs for halogen type bulb, but it wouldn't work in my application. To date, I have returned them to China, but the sell has not "received" them in order to give me a refund.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
