Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 04-28-2003, 05:08 PM   #1
want310
want310's Avatar
Profile:
toilet trickle
My trailer sat for a couple years. Could this be why the toilet doesn't flush? I checked to see if it was getting water preasure and it is. The PO said it worked fine and that the internal valve may be sticking. Is this something that requires removal of toilet or is there a fix somewhere that I can't figure out? It does trickle at times. Any help/ideas appreciated.........Steve
http://handicappedtravelclub.com/
want310 is offline   Reply With Quote
Old 04-28-2003, 08:01 PM   #2
PatrickDeBourke
Profile:
Hi Steve
I don't know the make-up of your toilet ,
I feel they are all similar. at the water tank, with your hand lift the ball flapper to run the water down through the bowl if you can complete this task, I sure you will see what internal parts in the tank that are not working properly .
Good Luck
Patrick
Patrick DeBourke
PatrickDeBourke is offline   Reply With Quote
Old 04-28-2003, 08:15 PM   #3
want310
want310's Avatar
Profile:
Thanks Patrick
This link will take you to a breakdown of the toilet
http://www.thetford.com/parts_aquamagicivfoot.cfm#8
Steve
Old 04-29-2003, 07:04 AM   #4
PatrickDeBourke
Profile:
Hi Steve
I did receive the drawing of the toilet
I would check Part # 24571 item 2 & 3 the wire may be streched which is a replacement part and try to
operate the water valve Part # 13168 by hand which is also a replacement part
Good Luck
Patrick
Patrick DeBourke
Toilet changing tips... drboyd Sinks, Showers & Toilets 2 07-18-2006 02:28 PM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 04:07 PM
64 Swirlomatic toilet MW64OVERLANDER Sinks, Showers & Toilets 1 10-27-2003 10:57 PM
Toilet replacement pinebenny Sinks, Showers & Toilets 2 09-23-2003 12:52 PM
remove/reinstalling the toilet Chuck Sinks, Showers & Toilets 7 07-28-2003 03:44 PM
