02-23-2011, 01:32 PM
#21
Austin
Certainly not my favorite topic, but I have no answer for you. My toilet has only one supply line.
02-23-2011, 02:32 PM
#22
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
all good ideas, but my toilet has pex run right to the toilet inlet and a crimp to male swivel pipe connector. Looks easy enought to do to me. probably have to make up an assembly and go back to where you have space to do the last cripm or use a shark bite there. Once I got on to the crimp fittings I have not gone back to the sharkbite.
02-24-2011, 10:27 AM
#23
1966 26' Overlander
Woodstock
, Georgia
I'll post a photo of the toilet connections.
02-24-2011, 10:58 AM
#24
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Sounds like a good idea. I can see one for the supply, one for a hand sprayer, but a third leaves me mystified.
Although, the possibilities send the imagination racing.
Vaughan
02-24-2011, 11:38 AM
#25
1974 Argosy 26
Morrill
, Nebraska
Only One
The toilet has one cold water line. My guess is the other two are the hot and cold lines to the shower. Or they are for the galley sink.
02-24-2011, 04:33 PM
#26
1966 26' Overlander
Woodstock
, Georgia
Toilet lines
so you all don't think I am more nuts than you already do--check it out...3 line go into the toilet...
02-24-2011, 10:43 PM
#27
1974 Argosy 26
Morrill
, Nebraska
That's a new one on me. Some fancy thrown!
02-25-2011, 10:09 AM
#28
1966 26' Overlander
Woodstock
, Georgia
I guess I am gonna split the pex and run the 3 lines, then see what happens. Hope no water explosions!
02-25-2011, 10:56 AM
#29
1972 31' Sovereign
Lexington
If it were me, I'd hook up a water line one at a time to the 3 connections. I'd start with the brass elbow at the bottom, and make sure the other two hoses are going to a bucket before supplying water pressure. Any idea where the other end of the two hoses go? It looks like the one on the right goes to the bottom of the bowl. The one on the left has a gizmo thing on it - does that come apart? Could be a check valve, or maybe a small filter.
Chris
02-26-2011, 06:03 AM
#30
1966 26' Overlander
Woodstock
, Georgia
That gizmo seems to be an old thetford filter. I can't tell much more, but your idea is a good one. Waiting in my supply line to get here then I will start being a hooker. Hooking up I mean. ...or should I say attaching.
02-26-2011, 06:48 AM
#31
2002 25' Safari
Dewey
I would guess that the water supply would only be connected to one of the lines. One of the other lines would be the water going to the bowl and the sprayer and would be controlled by the foot operated valve. The third line looks like the line to the bowl.
Richard
03-19-2011, 12:50 PM
#32
1966 26' Overlander
Woodstock
, Georgia
I hooked up a temporary line to the brass fitting, and routed the other two plastic ones to each other. The toilet barely dribbled water as my connection was poor, but when I stepped on the flush foot valve the water went thru the plastic lines. Still not sure what to connect these to, I think since they both went to an external filter, they are an out and a return. Once I find the right pex valve for the brass inflow line I will try it again.
03-22-2011, 10:30 AM
#33
1966 26' Overlander
Woodstock
, Georgia
I got it now. Connected the brass inlet ( flair) with a flair to pex fitting. Connected the two plastic hoses to eachother with a clear plastic hose and clamps. Works like a charm. I lubed up all the toilet mechanism and my wife made a new cover for the box on top. It is looking great now...PEX is almost finished.
I painted the sink with Krylon and it looks pretty good, clear coated it too.The new faucet was an Ebay item,$9.99!
03-22-2011, 11:11 AM
#34
1971 23' Safari
Marietta
, Georgia
Alan,
Looks good. Did you remove the sink from the wall to paint it do did you tape off the surrounding area?
- David
1971 23' Airstream Safari - "Moe"
2017 Ford F350 4x4 6.7 CCLB - Silver/Black - "Max"
03-23-2011, 09:48 AM
#35
1966 26' Overlander
Woodstock
, Georgia
I used blue masking tape and paper all around it. Worked well. Did three coats and then two of clear. I did get a small spot or two of little fish eyes looking circles. I sanded before hand but must have missed a small space. No one has really noticed them so I guess it's ok.
We will see how the Krylon holds up.
