Old 09-15-2011, 08:38 AM   #1
chisholmjb's Avatar
1986 32' Excella
1986 32.5' Airstream 325
Charleston , South Carolina
Exclamation Wires to water heater.
I need the schematics its not in my book. which wires do i hook up to my hot water heater. I just bought this camper, and the gas part is hooked up but the electric, was left with just the wires coming out of the box. could someone help me. My dad is coming over and he is an electrician, IBEW but colors would be great.and is there anything we should know going in, thanks again. john b
this book does tell me the colors for the DC but i only want to use the 110 stuff, i believe. also do i have to have a switch if im running electrical from outside?
chisholmjb is offline   Reply With Quote
Old 09-15-2011, 09:16 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Your electrician dad will be able to decipher the 110 wiring for the heater element. Standard black, white and green. maybe a bare ground. I just put a male plug on the 110 on mine and I plug it in to the campground power seperatly from the main trailer plug. I use a little plug in GFI in the circut. I can also plug it into the outside outlet on the Airstream if there is no seperate 110 plug at the campground, but there usually is. It looked like a lot of trouble to wire the 110 through the trailer. On mine there is a dual swithch and a indicator light that I put into the bathroom in place of the old switch, so I can turn the electric element on and off from inside if it is plugged in.
Old 10-25-2011, 02:52 PM   #3
chisholmjb's Avatar
1986 32' Excella
Thanks. I forgot to tell you, but thanks for your reply.
love camping go scouting. DO YOUR BEST
Old 10-25-2011, 03:52 PM   #4
Airstreams do not use "hot water heaters".
But...............they do use "cold water heaters".
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-15-2012, 07:44 PM   #5
musicmaster's Avatar
1976 31' Sovereign
Greenwood , South Carolina
HA HA HA HA. Didn't realize it had gotten that late yet.
musicmaster is offline   Reply With Quote
Old 03-15-2012, 10:24 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Not totally true Andy. Water heaters also heat warm water. But aren't we getting off topic?
I'm pretty sure your Dad can figure it out with his background.
Old 03-15-2012, 11:19 PM   #7
But "warm" is relative and subject to opinions.
Andy Rogozinski
Inland RV Center
Corona, CA
Bare wires above water pump??Interstate 3500 2012 TY PECK Electrical - Systems, Generators, Batteries & Solar 2 01-23-2012 03:15 PM
Fresh water tank: Level sensor wires Keyair Fresh Water Systems 6 12-18-2010 11:12 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Propane Heater HOT with nearby wires tetstream 2005 and newer - Bambi all models 3 12-23-2007 12:28 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
