04-20-2010, 12:31 PM
1958 22' Caravanner
gregory
, Michigan
OK I am almost ready to cut into the AS Caravanner
After reading the adjacent thread about Precision temp water heaters I have almost decided to go with the PT RV5000. What is the best way to cut the side out of the trailer. I never had a propane heater in the original trailer so can choose my spot.
Metal drill at corners and reciprocating saw with fine metal blade?
I like the ease of installation of the Precision Temp Shower Mate, but the cost is up there. Does anyone think its worth buying the High wind and Winter add-on for the PT RV5000?
Airdoxy
04-20-2010, 12:39 PM
Princeton
, New Jersey
I would not consider a reciprocating saw to cut the outside of the AS. Consider a small router or nibbler, the reciprocating saw and metal shears will bend the material along the cut and may not be covered by the flange around the heater. Check the flange dimensions before you use them.
2004 Excursion 4x4
04-20-2010, 01:55 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Airdoxy
I do. Even in Arkansas.
But I'm in my Excella in the winter.
Vaughan
04-20-2010, 02:22 PM
Greeeneville
, Tennessee
When I cut into the side of my classic trailer to make a refrigerator vent, I looked at the rivet lines and carefully measured the opening I needed to make. I started with the small hole made by a drill. Then I used hand metal shears to nibble away the metal, hoping I would not find a hidden wire of any kind. I was very fortunate and the vent install went smoothly. I can certainly understand your reluctance in cutting into the side of your trailer.
Kevin with Baity the Lab/Pointer //------AIR # 7303------\\ WBCCI 17109 visit my restoration blog at:
04-20-2010, 05:16 PM
1968 24' Tradewind
Oxford,
, Mississippi
I'd say stay away from recip saw. Things can go bad real fast if you make a mistake. A good jig saw with a fine metal blade might work OK, put blue tape down so the shoe of the saw doesn't mare the skin. I think the best would be an air nimbler, but hard to justify buying if you only use it once. Eastwood Company, check the web site, has a good manual metal nibbler. I bought one last year and it works well and does not distort the edge like shears can.
04-20-2010, 06:34 PM
banjobill
2000 30' Limited
battle ground,
small hole and look around
inho, small hole first, then inspection mirror with flashlite, then creep up on it with tin snips. the alum is easy to cut with sharp snips (not the 40 year old ones in the tool box-spend a coupla $ and get some new ones) don't use the recip-it'll jump around too much and the length of the blade will cause additional woes inside...slow and small is the ticket.
bill
04-20-2010, 07:19 PM
1964 17' Bambi II
Schererville
, Indiana
Harbor Freight has a pretty cheap nibbler that worked well on belly pan material for me. Your sides might be thicker than that, but it was WAY easier than a snips & the cuts were smoother.
Becky
1964 Bambi II
1988 Avion 32S
04-20-2010, 07:59 PM
2007 25' Safari FB SE
Eureka Springs
, Arkansas
I agree with 68 Twind. I hired a RV tech to install furnace and water heater in new location. I marked where I wanted it, but couldn't watch the initial cuts. He used a sabre saw with masking tape on base. No Sweat (except from me!).
PS: Rivet lines mark where NOT TO CUT!!
04-20-2010, 09:51 PM
1958 22' Caravanner
gregory
, Michigan
Thanks All! I like the cautious approach. I am now even leaning toward the 'Shower Mate' unit, because it requires only 3" opening in and 3" stack exhaust out. Maybe its worth an extra $400 to keep the old tin can looking original.
