Old 10-25-2004, 05:57 PM   #1
Cruiser's Avatar
1952 25' Cruiser
Dummerston , Vermont
Images: 45
Question hot water heater wiring
I want to install a combination LP/electric HWH. Will this typically run on 12v or 120V? I rewired the trailer for 120V like the original wiring, and added a 12v circuit for pump, light, and a couple of outlets. I put 120v wiring in for the HWH, like the original, but now I'm wondering if it needs to be wired for 12V instead. Guess I should've checked this before, but I can still change it if I need to.
Doug
"Life is not so bad if you have plenty of luck, a good physique and not too much imagination." C. Isherwood
Cruiser is offline   Reply With Quote
Old 10-25-2004, 06:25 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Lutz , Florida
Images: 21
Send a message via AIM to thenewkid64 Send a message via Yahoo to thenewkid64
Doug,
The 120 Volt connection is all you need. There is a switch on the backside of the heater to turn the element on and off. The only reason you would need the 12 VDC connection is if you are going DSI on the gas side. If it is a standing pilot then no 12 VDC wiring is necessary.
When I wired mine in the back of the heater was too tough to get to. I wired it to a dedicated breaker because the breaker panel had space and was easier to get to. You will want to be able to turn it off if you plan to run the AC and have the heater running. The load will be too much for a 30 amp shore power connection and the pedestal mounted breaker will pop.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 10-25-2004, 06:46 PM   #3
Cruiser's Avatar
1952 25' Cruiser
Images: 45
So, I did it right without knowing it! Nice relief. Thanks, Brett.
As for the a/c, there isn't any The dedicated breaker sounds like a good idea anyway. The old HWH had a switch in the kitchen cabinet, that I was planning on replacing/reusing. Would this provide the same function, if I could just turn it off when not in use?
Doug
Old 10-25-2004, 07:46 PM   #4
Just a member
1978 28' Argosy 28
Lutz , Florida
Images: 21
Be sure that the switch is rated for the load that the water heater will need. If it is underrated you could have a potential fire starter. If you are going to use a normal switch I would put it in a steel box, with a steel switch plate for safety sake. Sharing a circuit for the heater plus??? could cause you to overload that leg, so I would be aware of that when wiring.
Brett G
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
HELP! - Hot Water Heater Diagnosis BrianRegan Water Heaters, Filters & Pumps 4 07-23-2004 03:13 PM
tankless hot water heater imeynstein Water Heaters, Filters & Pumps 19 04-17-2004 01:58 PM
Nobody needs a hot water heater!!! Rick Alston Off Topic Forum 109 02-13-2004 09:52 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
