08-31-2019, 11:26 AM
2018 28' International
Seattle
Gas water heater suddenly stopped working
On a recent trip the gas water heater suddenly stopped. I checked fuse at panel and water heater and they were fine. I tried lighting it at the tank and it singed my eyebrows....oops. Has anyone had this happen? The electric continued to work. I don’t hear the pilot light on the gas clicking, not sure though if it ever did. This is on a 2018 international.
08-31-2019, 12:29 PM
Fayetteville
, Georgia
The circuit board went out on the water heater in my 2018 Serenity 28. Wuickbeasy fix.
brick
2018 International Serenity
Cute wife...
08-31-2019, 01:23 PM
2017 27' International
Lake Havasu City
Check the thermal cutoff--a small electronic part in a clear plastic sleeve that's visible when you open the outside access door. If it looks singed, that's likely to be the problem.
Why would it be singed? An insect nest in the burner tube is the most likely cause. Clean out the tube, replace the thermal cutoff, and you should be good to go.
The other possible cause, as brick pointed out, is a failed control board. If the thermal cutout is intact, then you can replace that board. But don't waste your money on another Atwood board. Get a Dinosaur Electronics board. I've seen plenty of Atwood boards fail, but never a Dinosaur board.
08-31-2019, 07:32 PM
Seattle
So nothing looks singed, played around with it today and the gas water heater wants to start (tries two or three times, but no spark at all, smells like gas then the red comes on and stays on). We were camping for a week and it worked fine “last” night and then died.
Mine is a 2018 28 as well.
Is there a way to isolate and confirm it is the circuit board? If it was the circuit board why would the electric still work off of generator.
08-31-2019, 07:35 PM
1995 25' Excella
xxxxx
, xxxxxx
How is it trying to light if you have no spark at all?
Mine failed to light a year or two ago. I cleaned all the push on wire terminals and it hasn't given me trouble since.
08-31-2019, 08:11 PM
2018 28' Flying Cloud
Clayton
, Georgia
I have a 2018 Flying Cloud 28'. Circuit board failed six months after delivery. Installed a Dinosaur board as dealer could not get me in soon enough. No further problems.
PS. OP gets extra credit for not calling it a "hot water heater".
Erik & Carol
Clayton, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
08-31-2019, 09:58 PM
Seattle
There is a click “noise” but not typical to a normal pilot clicking to light. A normal pilot light goes click click click boom...
08-31-2019, 10:04 PM
1995 25' Excella
xxxxx
, xxxxxx
Have you looked for a spark?
08-31-2019, 10:14 PM
2022 25' Flying Cloud
NCR
, Ontario
two failures wi th dometic crappy circuit board
i gave up with dometic/Atwood and AS support
i did like other
no has ever bad a bad Dinosaur board.
09-01-2019, 11:03 AM
Displaced Beach Bum
2016 30' International
Texas Airstream Harbor
The Atwood boards are trash. Buy a Dinosaur Electronics UIB64 Ignition Board Available on Amazon for $122 and an additional 2 year extended warranty for $15.21 Total warranty period 5 years.
09-01-2019, 07:10 PM
Link’s Travels
2002 25' Safari
1999 35' XL 350 w/slide
LINCOLN
, Nebraska
Water heater problems
I also have a 2018 International Signature. I am on my "fourth" electric board. Wish I would have went with the non-compliant Dinosaur board instead of the crappy chinese board they are putting in the units now. They had some significant problems with the boards in many of the 2018 airstreams and perhaps the 2019 as well. Still occasionally have a problem with the board; cold water gets hotter than hot water??? Going to Jackson Center the 18th to have many warranty problems fixedD!!!
09-02-2019, 06:06 AM
2019 30' Flying Cloud
Grass Lake
, Michigan
Our 2019 FC had a similar issue, WH wouldn't work on either gas or electric when I got her out this Spring. Fuse on control board was blown, so I replaced that. It immediately blew again, so it was something more serious. Our AS warranty said appliances are covered by OEM, not them, so I called Dometic directly. They were very helpful and when I described the problem, they said, it was the control board. I offered to give them proof of purchase for the trailer and they even said, "that's OK, we trust you" and sent me a new control board the next day. 10 min install and it's worked fine all summer.
I thought about buying a spare to have onboard, until I saw the price. I'm going to have to look into Dinosaur Electronics.
09-03-2019, 02:36 PM
Airstream Ambassador
Jackson Center
, Ohio
Hi jathan,*
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customer_support@airstream.com*
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
09-03-2019, 06:10 PM
2017 28' International
Virginia Beach
, Virginia
There are more posts about problems with the Dometic igniter boards than one can count! I went through 3 before giving up and buying a Dinosaur board. It worked immediately upon installation - not a single problem since.
09-29-2019, 05:53 PM
Worcester
, Massachusetts
I am having a similar issue. My propane water heater would cycle on when it was off. Now it looks the attached picture. Any advice?
