Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 03-13-2017, 10:29 PM   #1
2012 23' FB Flying Cloud
Corvallis , Oregon
Cracked Moen water filter = no water use in our trailrr!
Our Moen kitchen water filter cracked in a freeze. Is there a way to use campground water without the filter? We're camping and can't turn on camp water without flooding our interior. I can't believe the the entire water system is not usable because of a cracked filter!
Annabellelly is offline   Reply With Quote
Old 03-13-2017, 11:16 PM   #2
Caffeinated's Avatar
2015 27' Flying Cloud
Newberg , Oregon
Assuming you are talking about the undersink filter, you should have a piece of straight tubing to put in its place. It comes with the trailer and screws into the fittings that hold in the filter. At least, that's the way it is with my '15 27 FC. Alternatively, many RV repair places should carry replacement filters.
Mike
Caffeinated is offline   Reply With Quote
Old 03-13-2017, 11:18 PM   #3
Granbury , Texas
Your trailer should have come with a filter bypass hose...look in that box of goodies that Airstream provided with your new trailer. I bet you will find it in there.
Just remove the filter and install this bypass hose...all good again.
We don't install this filter and just leave the bypass installed. We never drink the trailer park well water anyway so no need for the filter. We always drink bottle water when traveling. Safer!
I use a filter outside attached to the hose to clean out any contaminates entering the trailer.
cabinetmaker is offline   Reply With Quote
Old 03-14-2017, 08:25 AM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
If the filter froze and burst, you ought to check out the rest of your plumbing for leaks. After you replace or bypass the filter, one way to check for internal leaks is to disconnect the external water supply and make sure you have some fresh water in your storage tank. Then turn on the water pump and leave it on. It should shut off shortly when pressure is built up in the lines, and remain off for hours. If the pump keeps recycling on its own, you may be losing pressure through a leak (keeping in mind a bad check valve at the water pump can allow water to return to the water tank).
Doug and Cheryl
Old 03-14-2017, 10:28 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
To have been cold enough to freeze the filter, a large volume of water, you have to check the toilet flush valve in the base of the toilet, the head of the pump, and any metallic fixtures. If the plastic piping froze it will likely have pushed out the ends at an elbow.
2004 Excursion 4x4
Old 03-14-2017, 12:40 PM   #6
Rich W's Avatar
I'm In , Kentucky
Just curious, do you cook with the trailer park water? coffee? We use bottled for drinking and coffee but use the park water for cooking.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 03-14-2017, 01:04 PM   #7
ToyHouse
2014 27' FB Classic
Quesnel , British Columbia
Apart from the warnings about possible other freeze damage, if it is the kitchen sink filter unit......look way in the back of sink cabinet and there may be a shutoff valve plumbed specifically to isolate this Moen filter. Our AS has this valve but it is hard to see it at first glance.
.....Tom
ThomasHoward is offline   Reply With Quote
Old 03-14-2017, 04:26 PM   #8
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I'm not sure if you have told us if you are talking about an undersink filter, or one built into the faucet.
We have the one built into the faucet.
We never use it (we buy drinking water in 5 gal containers locally) but I think if it is split due to freezing your faucet will not function properly.
You can possibly get a replacement filter if still available from Moen. Otherwise, maybe there is a way to hook up a short piece of hose to replace he filter so the faucet will work as normal - maybe just patch up the damaged filter somehow!
I run plumbing antifreeze thru ours each winter to protect it - as mentioned, we don't use it for drinking water anyway. Maybe the antifreeze might not be good for the filter if you do use it for drinking water, although the plumbing antifreeze is supposedly not harmful.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 03-14-2017, 08:21 PM   #9
Corvallis , Oregon
Depending on the park, I usually use camp water not through the filter
Old 03-14-2017, 08:22 PM   #10
Corvallis , Oregon
.....Tom
Thanks...was able to find a replacement Moen at a local plumbing supply place!!
Old 03-14-2017, 08:24 PM   #11
Corvallis , Oregon
Thanks...we put lots if anti freeze in all drains but didn't remive the filter so ut cracked. We were able to find a Moen replacement at a local plumbing supply place and installed it....took my shower!!!
Moen Choiceflow 9600 water filter Gmutt Fresh Water Systems 1 01-01-2016 06:48 PM
Moen - Water Filter Drathaar Winterizing, Storage, Carports & Covers 2 11-08-2013 08:03 PM
Moen drinking water filter Bbelk General Repair Forum 2 09-18-2013 03:55 PM
how to remove moen undersink water filter on 2010 bambi dsrtgrls Water Heaters, Filters & Pumps 5 12-06-2009 07:38 AM
Moen 601 water filter jcanavera Water Heaters, Filters & Pumps 3 04-04-2006 09:29 PM
