Old 07-11-2003, 09:43 AM   #1
pilgrim_still's Avatar
Send a message via Yahoo to pilgrim_still
Thetford vs Valterra
I seem to have a hybrid system. In the photo, you can see where the monstrosity was created to match plumbing of different diameters.
Can I get a piece of plastic plumbing with the sewer connector nobs (do these have a proper name) to replace the monstrosity?
Where is the best source?
What is the difference between the Thetford and Valterra fittings?
tia,
JimF - a pilgrim_still <*}}}><
Waterproof, Louisiana
1973 Sovereign
"Preserve Game - Use a Trained Dog"
pilgrim_still is offline   Reply With Quote
Old 07-11-2003, 10:01 AM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Thetford is slightly larger than Valterra fittings. There are adaptors available. Most "blue tanks" have the Valterra fittings, as do most SOB's.
Parts? HERE is a good place to start.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 06-09-2005, 11:26 PM   #3
C Johnson's Avatar
1965 17' Caravel
1968 28' Ambassador
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
New Plumbing - looking for opinions
Goin to revive an old thread here. I pretty much have a blank slate to start with on the plumbing. Would it be wiser to use the Valterra fittings versus the Thetford ? I was told by a repair shop here in town that Valterra is the most popular and the easiest to get should something break. Let me know what you all think !
Chris
AIR # 7276, WBCCI # 7276
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 06-10-2005, 12:26 AM   #4
Creampuff
Creampuff's Avatar
2022 27' Flying Cloud
2016 25' International
Airstream - Other
Malibu , California
Images: 60
Chris
The original Thetford fittings coming out of the black tank on older trailers with no grey tank are fragile and obsolete according to my local dealer.
If you are building a system DEFINITELY use Valterra as they are universally available ( and cheaper).
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 06-10-2005, 06:04 AM   #5
Images: 59
The Thetford parts are definitely higher quality, but availability (and lower cost) definitely swing me toward Valterra.
Use rubber couplings and radiator clamps at critical joints so you can make repairs in any Home Depot parking lot.
Old 06-10-2005, 06:25 AM   #6
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I'll add hearsay in that I was told the reason Valterra dump valves are easy to replace is because they have to be replaced fairly oftern. No personal experience though.
Parts availabilty, as markdoane pointed out, is a definite plus.
Tom
Old 06-10-2005, 08:56 AM   #7
C Johnson's Avatar
1965 17' Caravel
1968 28' Ambassador
Butte , Montana
Images: 326
Good responses
Well it seems like Valterra is leading the pack. I had heard that Thetford is becoming obsolete by my RV dealer here too. The reason I ask about the fittings is I am getting a new holding tank made here in town. They will duplicate what I have for a fair price. I am actually gong to make it a little bit bigger. They have to have the fittings when they make the tank so they can match the materials. I can also get a no leak guarantee if they put the fittings on. A plus here is that after they make my tank, they will have the measurements and could easily make more.
Are the Valterra fittings made from abs ?? or some other kind of plastic.
Chris
Project 2k5
Old 06-10-2005, 09:20 AM   #8
I have a '71 Avion with Thetford fittings and wanted to use Valterra but could not find an Thetford to Valtera adapter. I called Valterra and they sent me an adapter free of charge.
Daryl
"If the women don’t find you handsome, they better find you handy.” Red Green.
TheLuvShack is offline   Reply With Quote
Old 06-11-2005, 01:34 PM   #9
C Johnson's Avatar
1965 17' Caravel
1968 28' Ambassador
Butte , Montana
Images: 326
All Valterra
I just got back from the RV store. I purchased all Valterra fittings. They are inexpensive and they confirmed what people have said on here. They are widely available. The store had everything I needed right up to the Blue Boy. yay ! Sooo...my whole AS is Valterra now.
Chris
Project 2k5
Source for Thetford valve? pilgrim_still Waste Systems, Tanks & Totes 10 06-28-2018 08:09 PM
Valterra to Thetford connection Craig Waste Systems, Tanks & Totes 30 03-05-2011 07:49 PM
Thetford Toilet Repair??? Galaxy Low Profile ViewRVs Sinks, Showers & Toilets 11 05-03-2010 03:27 PM
Thetford Drain Valve - Blackwater JHBurns100 Waste Systems, Tanks & Totes 15 04-07-2009 09:39 AM
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
