Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 06-30-2003, 09:21 AM   #1
Profile:
Replacing Black Tank 1966 Trade Wind
I recently purchased a 1966 24’ Trade Wind AS. The shell seems to be in good condition but there are many leaks in the plumbing and now it looks like there is some type of leak of the black water tank. My question is how to check the tank to decide if it needs to be replaced. I can see a lot of rust and some exposed Styrofoam near the tank drain. It seems my next step is to remove the some of the under belly in the rear and evaluate the degree of damage but I don’t want to remove anything I don’t need to. Any advice is appreciated. This is my 2nd week of demo and I’m a little nervous.
Pat Dolan
1966 Trade Wind
Suburban 2001
Pat66TW is offline   Reply With Quote
Old 06-30-2003, 09:43 AM   #2
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
I would find out if you have a leak before you tear into it.
I would first rinse the tank with the dump valve open. Close the valve and fill with clear water. If it leaks it should not be too nasty this way.
If it leaks then you will need to pull the under bumper wrap, belly skin and tank pan. In that order. Wear eye protection 'cause the sheer volume of stuff in the underbelly will amaze you. The pan should drop straight down once the belly skin is removed. The tank is held in place by the pan. The pan and a styrofoam tray is what hold the tank up, so drain it before removing any bolts.
My experience on the 65 Safari I had was that the bottom of the pan rusts out form water entering through the bumper and the belly skin conceals the rust. If the tank does not leak, I would keep an eye on it, but only open it up if you are prepared to have a new pan custom made. If you need a new tank, I think Inland has them.
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
Old 06-30-2003, 09:42 PM   #3
Profile:
Brett,
I did just as you said the other day and it does leak but with the belly skin on I’m not sure where it is coming from. I'm suspicious of how securely the tank is in place, it maybe that the leak is coming from the drain into the tank and with the added weight of the waste in the tank it leaks. I have a lot of rust and I need to do the rest of what you suggested. I'll be taking the under bumper wrap and belly skin off in the next couple of days and do a better inspection of how well the tank is held in place.
Pat Dolan
1966 Trade Wind
Suburban 2001
Replacing black and gray tank level indicators nickcrowhurst Waste Systems, Tanks & Totes 4 12-30-2003 09:42 AM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 08:59 PM
Black tank flush.... drboyd Waste Systems, Tanks & Totes 11 08-01-2003 08:40 AM
how long to fill black tank? Stefrobrts Waste Systems, Tanks & Totes 11 06-30-2003 12:14 PM
Replacing Black Water Tank Tamara Waste Systems, Tanks & Totes 15 06-18-2002 11:45 PM
