Old 09-22-2006, 09:59 AM   #1
Painted Post , New York
Interior Odor
My 75 Argosy has a bad oder that smells like sewer gas or propane coming from the kitchen counter area. Anyone have any experience with this problem? Thanks.
640fan is offline   Reply With Quote
Old 09-22-2006, 10:08 AM   #2
Elgin , Texas
Images: 164
Try the search engine for things like "odor" and "black tank". You'll find several results which will help you get started in the right direction.
Also, check for propane leaks around your stove and oven.
Welcome to the forums!
bake315 is offline   Reply With Quote
Old 09-22-2006, 10:57 AM   #3
McLogger's Avatar
Columbia , South Carolina
We had this problem. Check your oven pilot switch on the oven control knob. Make sure it is turned to pilot off it should be the first setting on the knob one click before the actual off position. Another thing we cam across is that the pea (??) trap had dried up and was stinking or the air from the tank was coming in when we are hooked to sewer??
Happy Camping
McLogger, AIR # 16452
McLogger is offline   Reply With Quote
Old 09-22-2006, 11:20 AM   #4
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Having an LP detector is a good idea if you don't already. We added one to the kitchen area, since all the propane appliances are right there.
I agree, could be the trap as well, ours smells sewer-funky sometimes when it dries out.
Stephanie
Old 09-22-2006, 05:41 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
LP detectors are to be installed at floor level because propane is heavier than air. Is the smell worse if the trailer is closed up? On entry can you get down on the floor and smell it more?
5 meter Langford Nahanni
Old 09-22-2006, 09:21 PM   #6
Elgin , Texas
Images: 164
Or, if you haven't already done this, turn the gas off at the tank, and see if the smell dissipates inside.
Old 09-22-2006, 10:09 PM   #7
Barkingdogg's Avatar
Newcastle , Oklahoma
Do you have refrigerator running on propane? Could be the fumes from this if exhaust chimney is not sealed off.
Barkingdogg is offline   Reply With Quote
Old 09-22-2006, 10:42 PM   #8
AIR #8691
2006 25' Safari SS SE
Northern , Virginia
If not propane gas, check the sink drains for any accumulation of stuff. I add a small amount of holding tank deodorant to the sinks after every trip. That appears to take care of minor smells on the next trip out. http://www.airforums.com/forum...es/flowers.gif
JStanley is offline   Reply With Quote
Old 09-23-2006, 07:41 AM   #9
Dave, you remind me. It's amazing how much pressurized liquefied gas remains in the line after you turn off at the tank. Run the stovetop until it goes out.
After the gas is all off, sniff inside lower cabinets, bins below the beds or gaucho, etc. A nasty musty smell might indicate a leak and floor problem. It's amazing how much better my Argosy smelled after replacing bad floor areas.
Old 09-23-2006, 08:57 AM   #10
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
also
make sure your batteries are not overcharging. if they boil dry they can emit a rotton egg smell.
john
you call them ferrets, i call them weasels.
