View Poll Results: TO VENT OR NOT TO VENT?
YES - vent the gray tank through the roof
23 |
95.83% |
NO - just keep the tank clean and it will be fine
1 |
4.17% |
10-01-2015, 09:08 AM
1950 21' Flying Cloud
1960 22' Safari
Newland
, North Carolina
gray water tank - does it really need a vent?
I am installing a 9 gallon gray water tank in a 1950 Flying Cloud. The tank will sit under the galley sink and will be used solely for water from the sink. I do not expect to use the sink for much heavy dishwashing. It will just be used for light rinsing here and there.
I am wondering how crucial it is that my new gray water tank have a vent plumbed through the roof or side of the trailer?
I think it is likely that I will keep my tank pretty clean and I will not be using it much. If the vent is mandatory then I'll bite the bullet and drill a hole in my virgin exterior. But if I could get away without a vent I'd love to keep my exterior intact.
All suggestions will be appreciated!
Thanks!
Ryan
Ryan Franks
1974 Sovereign Land Yacht 31'
1950 Flying Cloud 21'
1960 Safari 22'
Newland, NC
10-01-2015, 09:28 AM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
If you don't vent it somehow, you are going to get occasional bursts of sewer gas into your trailer. Depending on how you use the sink (and your reported use is as benign as possible) you might be able to get away without one. But to be safe, I'd find a way to vent the grey tank to the outside. Have you considered looping the vent stack back under the trailer so it's less obvious? This will not be as effective as a straight up vent, but it's probably better than letting the gas escape into the trailer.
Bob Martel
WBCCI# 5766
10-01-2015, 10:34 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
The main reason for venting has nothing to do with tank cleanliness or odor. It has everything to do with the fact that the tank is not pressurized.
You start off with a gray tank full of air. As water runs in, air has to go out somewhere. When the tank is full of water and you go to dump it, as the water runs out, air has to get in from somewhere. The vent takes care of letting air into and out of the tank.
It's as simple as that.
Now, the reason for venting to the outside, though the roof, is because the tank IS a source of odors, so you want it vented to outside rather than to inside the trailer.
10-01-2015, 08:26 PM
1960 22' Safari
Newland
, North Carolina
The Airforums are a wonderful resource! Thank you Bob and Protagonist for helping me understand my situation with the gray tank. I like the idea of a vent that loops back under floor. I'll look into that. If not, I guess a small vent in the roof is no big deal.
Ryan Franks
1960 Safari 22'
Newland, NC
10-02-2015, 10:21 AM
1999 34' Excella
Hillsboro
If you are close to another "vent" going thru the roof, tie together up above the level of the sink.
Another less desirable option would be to vent from top of tank thru the floor... But that can cause more critter issues.
Peace and Blessings..
Channing
WBCCI# 30676
10-02-2015, 12:02 PM
2012 23' FB International
Woodstock
, Ontario
You can install a cheater vent under the sink....most Airstreams have one under the bathroom sink. It is a spring valve or lightly weighted check valve. Get it at your plumbing supplier; Saves cutting holes through the aluminum skin. It only vents when there is water going into the tank. I have never had a problem with odors from this vent It is needed to let the water drain through the trap in the sink. Without it your sink will not drain or it will take a long time to dribble around the air lock under the trap.
JCW
10-02-2015, 12:33 PM
1999 34' Excella
Hillsboro
With under sink you will need to monitor tank level closely.
Channing
WBCCI# 30676
10-02-2015, 12:49 PM
Superior
Maybe a giant 2" PVC vent is not preferred, but no vent is an issue too. Split the difference? Maybe run a PEX sized vent tube up through the walls to the roof refrigerator vent?
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
10-02-2015, 01:31 PM
1959 24' Tradewind
Twin Falls
, Idaho
I would think the check valve under sink or tie into your bathroom vent if they're on the same side.
10-02-2015, 02:16 PM
1967 17' Caravel
Oak Creek
The under sink vents also should be 6.00" minimum above the trap.
Or at least that is what is recommended.
10-02-2015, 03:01 PM
2015 30' Classic
Sherwood
, Oregon
It will also empty more slowly without a vent as air will have to overcome the P-traps.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
10-02-2015, 03:55 PM
1972 31' Sovereign
Lexington
The air admittance valves that are installed under the sink are only there to allow air into the drain above the p-trap so as water flows from the trap to the tank, air is allowed in to help with water flow and keep the trap from having all the water sucked out of it while the sink is draining. It will do nothing to vent the air out of the gray tank, or allow air to enter the gray tank while draining it without sucking the water out of the trap first. The tank needs to be vented. No, it doesn't need a 2" vent pipe, a flexible 1" pipe will work just fine. We tied our black and gray tank vents together, so we only have one vent pipe going out the roof.
Chris
10-03-2015, 08:23 AM
League City
Did you consider using a sink insert to achieve a similar outcome (with a lot less work)? Perhaps you did, but I didn't see it mentioned here so I thought I would offer that idea as an alternative to a sink-only gray tank.
I use the 2-gallon nylon camping sink shown in the attached photo to capture sink water so it doesn't fill up my existing gray tank, which is very small. The photo to the right shows a polyethylene basin used by blogger Brent Rose to achieve the same thing in his Class B. Just lift by the handles and deposit the water outside.
10-03-2015, 03:32 PM
Woodstock
, Ontario
Re my post number 6...My Bad...Minno's right. It is an air admittance valve not a vent valve so it will not vent the tank. I like the idea of routing a small line up under the sink and then back down through the floor. That way there is little chance of water draining through the vent
Re post number 13..That's what we do to take the load off the Grey Water storage, We keep the bits and pieces of water in a tub in the sink, add hot water at supper to wash the dishes and then ( if possible...not always so...) water the 'flowers' with it
JCW
10-30-2015, 07:43 AM
1955 22' Safari
Laredo
Vents
When I added gray and black tanks to my 55 FC I tied the vents into the existing sink vent that runs through the roof.
10-30-2015, 09:33 AM
Oswego
This is how mine is plumbed from the factory. Gray vent tee'd to the black vent with a single common vent through the roof.
-Rich-
06-04-2020, 07:13 AM
1972 31' Sovereign
Sanford
, North Carolina
JCW
Just what I have slow drains. I will get this one done. I rebuilt a 1972 31 ft Soverign. Changed everything around inside. Got all piping tested and plumbed in a city water connector.
10-16-2020, 08:25 PM
1958 26' Overlander
1962 19' Globetrotter
los angeles
I have 1962 `19' Globetrotter that had a black tank insider trailer vent that ran through closet to roof on curb side. Kitchen sink has vent that runs through roof on street side. Bathtub, bath sink and kitchen all ran to vent under trailer for drain to blue-boy.
Bathtub had p-trap under floor and bath sink had a p-trap inside cabinet.
We removed black tank and are installing a grey tank from VTS.
Bathtub and bath sink will drain to rear side wall of grey tank. Kitchen will drain to top or from side of grey tank. Due to re-configuration inside trailer, we don't want to run grey tank to vent that was previously used for black tank as it will be outside of closet.
Will the vent that runs off kitchen sink be adequate to allow the grey tank to fill to capacity or do we need to run an additional vent to the tank?
Any guidance is most appreciated.
