Old 07-08-2020, 09:51 AM   #1
2020 27' Flying Cloud
Black tank valve not closing. Here's the reason.
Hello everyone,
After my last trip, I brought our 2020 FC 27FB home and hooked up to our septic to dump the tanks and do a good flush. After taking some time to allow the blank tank to flush out I tried to close the valve and it went in but would not close all of the way, lacking about 3/4 of an inch. I called to make an appointment to have the valve checked out, but that wasn't for a couple of weeks, so I spent some fun time inspecting inside of the black tank outlet with a pipe inspection scope. I could see something blocking the valve from shutting. I was able to get a coat hanger and was lucky enough to be able to pull it out and you can see the result. It almost looks like a piece of fake poo. I believe it is just a 4 inch wad of caulk. I just cant understand how this would get inside of the black tank and wonder if there is more......
Brainodo is offline   Reply With Quote
Old 07-08-2020, 09:56 AM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Not surprising. They seem to just toss scraps here and there where they can't be seen when building an AS...My trailer has rivet stems, aluminum shavings, and aluminum scraps behind the gaucho, in cabinets and in other out of sight places.
CRH is online now   Reply With Quote
Old 07-08-2020, 10:00 AM   #3
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Brainodo,
Go buy a couple lottery tickets. NOW!
Only suggestion I can offer is a big water only flush to rinse out any construction debris.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 07-08-2020, 10:10 AM   #4
2018 25' International
Slidell , Louisiana
Airstreams are hand built and stuff gets dropped unfortunately. Had many scraps (mostly small) come out of my tanks at first but I have a Sewer Solution which backwashes the valves so nothing ever got stuck.
Brian
Old 07-08-2020, 10:12 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Ahh yes...we had a Bic lighter and & sandwich bags under the rug in the r/r storage compartment.
Along with various fasteners that fell out of the power driver before it hit its mark, or ones that missed their mark completely or some that remained next the second or third attempt.
Git 'er done.
Tahawus
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 07-09-2020, 10:10 AM   #6
2019 25' International
Washington , Washington, D.C.
The owner of the campground where I am currently hooked up, told me that when the round hole into the black water tank is drilled out (to allow for toilet/piping installation when RV is being built), that little silver disk falls inside the black water tank where it is often left behind. It can move about when dumping the tank and potentially cover the valve hole.
PatLee is offline   Reply With Quote
Old 07-09-2020, 10:37 AM   #7
Ray Eklund's Avatar
2019 27' International
2014 25' International
Fort Saunders , Wyoming
If the system works after your surprise. Quit worrying.
You did a great job extracting the caulk and no doubt you will live happily ever after.
It is like having a relative taking a look at your trailer and deciding to move into it while you are out of town. Once the in-law is extracted, lock the door and the problem solved.
If I have a Grey or Black Water issue... I will be coming to see YOU. Great work!
Human Bean
Ray Eklund is offline   Reply With Quote
Old 07-09-2020, 11:17 AM   #8
CRH
1995 25' Excella
xxxxx , xxxxxx
We have a tractor that had the diesel tank installed that way. The shavings clogged up the fuel filter over and over. We had to put a separate filter inline before the regular filter. We use clear filters so we can see the plastic shavings. 10+ years later and little bits of plastic are still showing up.
Old 07-09-2020, 12:17 PM   #9
Mollysdad's Avatar
I found a tip from a tube of calk in my outlet.
It probably got tossed in there before the tank was sealed up.
I was lucky.
Old 07-09-2020, 02:45 PM   #10
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
Good trouble shooting and fishing. Great for solid objects, however for normal black water contents it is a good idea to open and close the valve several times as the contents are flowing through. That will keep the valve groove (seat) clear. In your case that may have caused bigger problems if the valve jammed. Go easy at first.
guskmg
Old 07-09-2020, 05:31 PM   #11
2018 28' International
Fayetteville , Georgia
What did you eat?
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 07-09-2020, 06:25 PM   #12
2002 19' Bambi
Lafayette , California
... when the round hole into the black water tank is drilled out (to allow for toilet/piping installation when RV is being built), that little silver disk falls inside the black water tank where it is often left behind.
That's what we had and then the plastic disk ultimately ended up blocking the valve. Fortunately the blackwater drain pipe is large enough for me to get my hand up to the valve. That hand was washed thoroughly afterwards
Tim
Tim A. is offline   Reply With Quote
Old 07-10-2020, 06:49 AM   #13
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Veterinarians have gloves that extend all the way to the shoulder. Have you ever seen photo's of them reaching into a horse or cow. Would be a good addition to the Airstream tool kit.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 07-11-2020, 06:07 PM   #14
GCinSC2's Avatar
Yes, rescue squad respond please with hazmat suits and saws. Uh huh yes third site on the left past the playground. Yup the silver trailer. Iíll leave a light on for you guys.
Yes his arm is fully wedged in the black tank.
Ok blame the pandemic and the heat.
S/OS #001
Old 07-11-2020, 06:26 PM   #15
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
This may be safer to use!
I am going to send a box to the guys over in Jackson Center
PB_NB is offline   Reply With Quote
Old 07-15-2020, 12:09 PM   #16
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Assuming that you have a polyethylene (plastic) tank, that looks like “drool”. IOW a remnant of the molding process. Harmless.
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 07-15-2020, 01:24 PM   #17
2019 22' Sport
St. Louis, MO , MO
The thing that amazes me is the commonplace acceptance by AS owners of what is clearly a sloppy manufacturing process. When you think of the brand marketing, hype, COST, the quality you expect from the AS premium line of travel trailers is marginal at best. Push it out the factory door and let the owner and dealer work it out. My 2019 22FB Sport has been to the dealer 5 times in less that 2 years; Replacement of the 6 year old battery that came right from the factory, a bad check valve in the water pump, at least a dozen popped rivets, the privacy screen on bedside that falls out every time I pull the trailer, water heater control board failure..twice, erratic operation of the Dometic AC unit, and most recently over the past weekend a defective key core in the door latch that forced me to cancel ten days of camping reservations at the last minute. That one cost me $200 to have a locksmith drill out the core which ultimately allowed the door to be opened (now with two screwdrivers) but unusable since closing the door when inside the trailer you have a whole different problem as you can guess. Every time I roll out I'm thinking 'what's next' and who needs that anxiety when on a 2-3 week road trip? Airstream THOR rides the iconic brands past and banks on it's cult like following who seem to forgive any failure as normal and just the cost of ownership. Why not expect and demand better, I just don't get it. I don't mind a little troubleshooting and I'm enough a DIY guy to fix little stuff but why should I even have to with a unit I bought brand new and owned for less than 2 years. Would anybody stand still for such poor quality in car or truck you spend big bucks for, I doubt it no matter how pretty it is. The local AS dealer service department is booked out another month so I'm grounded until then. In any case I've had enough and I'm selling and starting over.
SteveF STLMO is offline   Reply With Quote
Old 07-15-2020, 01:34 PM   #18
PB_NB's Avatar
2019 22' Sport
WOW Steve, sorry to hear about your troubles. I have the same trailer and some of the issues that you have. I have not had a system failure yet such as the water heater... Did I read that correct that you had a 6 year old battery onboard? dated somewhere in 2014?
I guess you can put the poop shaped plastic in the same QC category as the issues that we are having.
It is fortunate that Brainodo was able to retrieve the plastic and saved a trip to the service department.
Old 07-15-2020, 10:02 PM   #19
2017 25' Flying Cloud
Vista , California
Fine trailers...for me
Hi Steve!
Iím so sorry you had so many problems. I bought my 25fcfb new in 2017. Iím sure I had some issues but I canít remember any of them. And Iím an exacting retired engineer.
I wonder how many have had experiences like your vs mine...
JohnSn is offline   Reply With Quote
Old 07-15-2020, 10:24 PM   #20
rd tighe's Avatar
2007 25' International CCD FB
South , Texas
Images: 12
Steve,
Sorry to hear about your trouble. If you want to compare storys we could talk about my former 07 Dodge. It's gone but the airstream is still going.
Richard (Dean) Tighe
W.B.C.C.I. 5617
2007 25' FB International CCD Solar
2019 Toyota Tundra
rd tighe is offline   Reply With Quote
Black Tank Valve Stuck in ON. Tank not emptying. eyechip Sprinter and B-van Forum 3 09-25-2018 10:07 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
sewer valve not closing Lebowski Plumbing - Systems & Fixtures 9 06-18-2013 04:44 PM
Steps Opening And Closing For No Reason wb13798 Mechanics Corner - Engines, Transmission & More... 22 07-15-2005 06:06 PM
Reason #2303 Jeep Should not Tow JodynJeep Tow Vehicles 4 09-15-2003 05:10 AM
