Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 11-28-2006, 10:23 AM   #1
1958 26' Overlander
Shreveport , Louisiana
58 Overlander Black Tank?
I did a search and best I can tell the 58 Overlander would have an above floor black tank with the toilet mounted on top.
If this is the case the PO took the tank and toilet out when he replaced the flooring. Is there any reason not to put a cheap home toilet in since I will be hooked up long term with water and sewage?
I was thinking I would go with a small, surplus 110 water heater and home toilet to get things going on the cheap, and change them out later. Any compelling reasons not to?
FastCars is offline   Reply With Quote
Old 11-28-2006, 01:42 PM   #2
Retired.
. , At Large
Not really, as long as you mount it so water doesn't get on the floor. Most early travel trailers had regular toilets in them anyway before the advent of the black tank, and RV toilet.
If you do, I would wire the water heater to an outside breaker panel, so when the time comes to put in a regular LP water heater, all you have to do is pull the wires out, and install the LP heater. There is flexible conduit to make this a neat, professional-looking job.
Old 11-28-2006, 01:51 PM   #3
1958 26' Overlander
Thanks.
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
Replacing Black Water Tank Tamara Waste Systems, Tanks & Totes 15 06-18-2002 10:45 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
