Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 08-02-2003, 03:58 PM   #1
gwilliam's Avatar
Profile:
Water leak from Holding Tank Drain
Have just filled my tank with the disinfecting solution prescribed by Airstream and now have a drip from the drain.
I removed the inspection cover and confirmed the drain plug is leaking and my first question is does anyone know the size of the hex wrench required to fit the drain plug?
I followed the Airstream procedure which is 1/4 cup of bleach per gallon of water and use 1 gallon of this solution for each 15 gallon of tank capactity. Wouldn't have thought a 5-6% bleach solution would disturb the seal to cause a leak. No problems before but the tank had been sitting empty for a while. Is it possible that is detremental and could result in a leak if sitting around in 90deg plus temperature, although we haven't had that many of those days this year yet.
I would be interested in any insight available.
thanks
Graham Williams
...If I didn't spell it right consider me kreative...
gwilliam is offline   Reply With Quote
Old 08-02-2003, 04:23 PM   #2
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
mine too
gw,
i didn't need a wrench, mine basicly fell out because the threads were gone!
here is a thread i posted on my repair.
http://www.airforums.com/forum...&threadid=5206
john
Old 08-02-2003, 04:46 PM   #3
gwilliam's Avatar
Profile:
John,
Good pictures and thanks for the info. Have you had the 92 from new?
Hard to believe that the potable water has that kind of effect!
My petcock turns ok and does not apear to be leaking anywhere. My problem is with the drain plug. Of course it is pretty tough to get a good look on the driveway and was just wanting to tighten.
Who knows maybe I would have got drenched. I think I will drain it before doing anything!
thanks again
Graham Williams
Old 08-02-2003, 04:59 PM   #4
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
graham
i too was suprized by the condition of the plug.
the bleach must have affected it, it seemed like a little different type of plastic. or rubber perhaps.
the good news is, that it is 1 1/2" pipe thread. should be able to find a replacement plug made of p.v.c. at any good hardware store.
unless all of your plumbing up north of the border is metric!
i am the second owner of my trailer, it was in the family. i was at the dealer the day it was delivered.
john
Old 08-02-2003, 05:16 PM   #5
gwilliam's Avatar
Profile:
John
Not there yet with plumbing in Metric but will keep the ISO standard book handy because I am sure it is coming!
Draining it now and I will check it tomorrow and get a 1 1/2" pipe plug if required. Of course if it doesn't fall out I might need a wrench as I can only muster a 5/8" and that might somewhat challenging here on a Sunday
thanks
Graham Williams
Fresh water tank leak Flex Fresh Water Systems 3 09-30-2004 05:25 AM
That pesky grey water that bypases the holding tank Van All Argosy Trailers 15 08-13-2004 08:52 AM
Front Holding Tank Leak Deejay Fresh Water Systems 0 07-08-2003 08:29 AM
Water tank drain Craig 1978- 1979 Excella 500 8 08-24-2002 10:02 AM
White water tank drain ramoore53 Fresh Water Systems 4 05-01-2002 11:08 AM
