The PO had put a piece of heater hose in the cold water side of the copper in the bathroom closet. I winterized by filling all traps and pump w/antifreeze and blew out the lines from city water supply without a water heater bypass. I sweated in copper in place of the rubber today before the new
12v setup goes in there, But when I pressurized the plumbing system w/40psi to soap those joints I dont think I had pressure on that line as the cold side of the lav faucet would not blow air but the hot side would . The hot and cold in the galley blew air as well as the supply to the water closet. Do you think I have a low spot that has a ice block. I put a elec. heater in there as its going down to 9 degrees tonight. Any advice would be great so I can continue my
12v work. Robert
