Old 04-25-2010, 11:30 AM   #1
Globie64's Avatar
1964 19' Globetrotter
South Kingstown , Rhode Island
Images: 18
priming the pump
Now we have a fully functional and non leaking city water supply plumbing system, I tried to fire up the old plunger type pump. It spins, but I wonder if there is some way to prime it? Its probably needing to be replaced, but I'd like to see if it is functional, if it can be made to work. It's so cool, with all the exposed mechanicals....
I don't know if it is original, but it has the electric motor on top, a toothed belt and the plunger that goes up and down when switched on.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 04-25-2010, 01:16 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
My Airstream depends on a FloJet VSD
Those pumps are cool looking. I have two of them.
Both of them work, but neither are plumbed into my American Classic because they are too doggone loud.
These pumps are self-priming upto 29 feet or so of head. If yours is not immediately pumping water then there is a problem. Problems could include:
  • No water to pump.
  • Obstruction in the line (before or after pump).
  • bad check valve in pump.
Tom
Old 04-25-2010, 02:32 PM   #3
Globie64's Avatar
Images: 18
OK, thanks. Yeah, it is loud... at this point, it's kind of a novelty. I'll check the check valve, there is water in the tank and the level is about level with the inlet on the pump. There was a lot of crud in the lines, which I've flushed out. I'm amazed it still runs
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
Just one more thread about priming/painting afinpdx Upholstery, Blinds, Walls & Interior Finishes 3 09-14-2005 06:01 PM
Priming? Mike & Deb Upholstery, Blinds, Walls & Interior Finishes 1 01-24-2005 05:50 PM
Pump priming subtlety koltys Water Heaters, Filters & Pumps 1 08-09-2004 10:02 PM
