Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 06-08-2006, 09:51 PM   #1
LTD30's Avatar
1999 30' Limited
1978 24' Argosy 24
Olympia , Washington
Thumbs up Insulate those hot water pipes.
While you’re doing plumbing consider insulating the hot water pipes. A year after we got the Airstream we put foam insulation every where we could reach (30’ worth) and noticed a difference right away. Especially in winter. When the water has been tuned off awhile and we turn it on again we can feel the cold spot under the coach when that water runs out the faucet. Now that we have to repair a leak from the hot water heater we can reach more pipe.
LTD30 is offline   Reply With Quote
Old 06-09-2006, 09:21 AM   #2
Wabbiteer's Avatar
Jupiter , Florida
Can you define 'foam everywhere we can reach' a little better?
The factory insulation on my '73 has turned into spiral wound ribbon loosely covering blue-green copper pipe, the insulation part long ago decomposed into a moisture retaining dust. I've got felt pipe insulation I found for free and am looking for more options ...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 06-09-2006, 03:23 PM   #3
LTD30's Avatar
1999 30' Limited
1978 24' Argosy 24
We used the 4' long split foam that can be bought at Home Depot or Lowe's.
We cut it to lengths as needed. Some places that we couldn't really reach (like behind the kitchen counter) we just shoved it over and along the pipe as best we could.
Water Heater Replacement rpwx Water Heaters, Filters & Pumps 2 04-23-2014 01:43 PM
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
hot water heater Mary Water Heaters, Filters & Pumps 2 08-12-2002 09:15 AM
hot water heater 53flyingcloud Water Heaters, Filters & Pumps 4 07-08-2002 10:18 AM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
