Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 10-21-2009, 08:14 AM   #1
Airstreamin and luvin it
Commercial Vendor
Devoman's Avatar
Profile:  2005 25' Safari
Northwest Panhandle , The Sunshine State/WBCCI 6637
Fresh Water hose
I am looking into getting a new fresh water hose for outside.I am looking for something I can roll up really easily and not have to worry about looping the hose up any more.I am just getting tired of doing this all the time now.I end up putting it in plastic bags so if there is any left over water in the line it does not run out into the floor.I have seen one that rolls up onto a wheel and it seems pretty good but it is really big.Anything that is small and compact?Any suggestions or what have you all done to make life easier.
Blue Numbers and Signs
E-mail me for quotes.
Devoman is online now   Reply With Quote
Old 10-21-2009, 08:34 AM   #2
Silverhobby's Avatar
Profile:  1956 26' Cruiser/Overlander
1957 26' Overlander
1962 22' Flying Cloud
Vale , North Carolina
Steve, I made several lengths of hose and installed brass ends into it for my own perfect hose. I made a 4 ft length to go from the water hydrant in a camp to my filter, and I have a 6 ft section, and also a 10 and a 20 foot section. These are made of clear, braided 5/8" with brass fittings. These hose lengths have served me well for many years.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 10-21-2009, 08:42 AM   #3
Luckyducks's Avatar
Profile:  Panama City Beach , Florida
Steve, I coil up my hose when breaking camp and then put bungees around it to keep it in a tight coil. I then screw the ends of the hose together so water doesn't spill out while in storage (and too keep bugs out).
Russ and Linda
2002 25' Classic "Camp Luckyduck"
2002 F250 Crewcab Powerstroke 7.3
AIR#24440
WBCCI#11740
Luckyducks is offline   Reply With Quote
Old 10-21-2009, 08:57 AM   #4
SilverRanger's Avatar
Profile:  2005 19' Safari
1968 24' Tradewind
Milton , Delaware
I have one of those roll up hoses. It's 25' long, and rolled up it measures approximately 14" x 14" x 1 1/2" thick. It rolls up flat and squeegees the water out. The one you have pictured seems pretty compact. There are several kinds out there. Just make sure you get the RV/boating type. I use mine as a back-up and as an extension to my regular hoses which I keep coiled up inside a waterproof nylon bag.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WBCCI# 4582
WDCU
SilverRanger is offline   Reply With Quote
Old 10-21-2009, 12:28 PM   #5
2airishuman's Avatar
Profile:
Originally Posted by Devoman View Post
I am looking into getting a new fresh water hose for outside.I am looking for something I can roll up really easily...
hi devo
the 'roller hoses' are great for extras, back up, reaching distant source and so on...
but LOUSY for everyday use.
the fittings are weak the hose is thin, the FLOW is slow, they are MORE prone to mildew inside, and so on...
____________________
the permanently coiled hoses have really good brass fittings and are durable and compact.
but the narrow size limits flow/pressure. (for some this is a good thing)
but THIS STYLE have been used the most, is quickest to stow and drain and most durable for daily use.
CW sells these in 25s and 50s in 'blue' drinking water safe color...
_____________________
like 'hobby i cut a quality rv/drinking water hose into sections and added brass ends.
this lets me use only enough and add inline filters easily.
with ANY of these hoses the issue of mildew and bacteria growing INSIDE the hose is still present.
so the hoses need to be sanitized from time2time and the ends COVERED to avoid critters and boogers getting inside.
______________________
disclaimer:
i carry ~175 feet of hose including 2 of EACH of these (roll up, coil, standard) and a 'spare' brand new/unused/packaged hose....
just in case
cheers
2air
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 10-21-2009, 01:04 PM   #6
doug&maggie's Avatar
Profile:  Normal , Illinois
We bought a 50' permanently coiled hose before this last trip, and it was one of the best decisions we ever made. Water pressure isn't as good, but certainly adequate, it takes up less than half the space in our small rig and is just so much less annoying than the regular hose. Coiling that thing and getting it back into its' cubby, especially when cold, was a royal pain. We continue to carry a 5' hose for fresh water fill.
li'l moose
The more you know, the less you need
doug&maggie is offline   Reply With Quote
Old 10-21-2009, 02:03 PM   #7
RLS
RLS's Avatar
Profile:  2004 25' Classic
Longwood , Florida
We have 3 water hoses, one is 10' and the other two are 25' ea. All are coiled up with the ends screwed together and put on top of the propane bottles under the lid. Usually all we need is the 10' and it is very easy to coil up. Once a yr. I take them out and put them in the tub with some water and chlorine to soak for a while.
RLS is offline   Reply With Quote
Old 10-21-2009, 03:00 PM   #8
Commercial Vendor
Devoman's Avatar
New lines
I am needing some new ones.These look pretty beat up now.Any more suggestions on what everyone uses.Also...What is a good water filter to use.
Old 10-21-2009, 03:25 PM   #9
Profile:
now u r getn lAzE...
fill-terz are well covered as are hoses really...
Need water filter advice.
Water Pressure Regulator & External Water Filter
2 filter water system
Hard Water Blues
Potable water question from a newbie...
cheers
2air'
Old 10-21-2009, 03:34 PM   #10
RLS
RLS's Avatar
Longwood , Florida
Here is what I have, Hydro Life RV/Marine Exterior Water Filter Kit - Item - Camping World and it does work good. Here are some shots on it stowed away and hooked up.
ID:	89498   Click image for larger version
Old 10-21-2009, 05:33 PM   #11
Commercial Vendor
Devoman's Avatar
I know.sometimes I get like that.
Thanks for the links 2Air.
What about the quick disconnects.I had some break on me in the past.What it had broke was the seal because when I would clip them together it would leak really bad.What do you all use that has worked well with the hoses?
And what type of water hose connectors did you all use to put them together.Plastic,Brass,Stainless?
Old 10-21-2009, 07:21 PM   #12
cosmotini's Avatar
Profile:  2008 27' International CCD FB
Highland , Illinois
Images: 83
I bought some of these at a home-show in St. Louis. I use the big one to store a 25' 5/8" fresh water hose. It works out pretty well.
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 04:28 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 02:23 PM
Fresh water hose - keep it clean? Sierrapapa Fresh Water Systems 15 07-20-2007 06:04 PM
broken fresh water tank hose Lumatic Fresh Water Systems 1 07-05-2007 08:53 AM
No Fuss Flush and Fresh Water Hose? docbluedevil Waste Systems, Tanks & Totes 3 04-07-2004 11:07 AM
