Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 06-26-2011, 09:46 AM   #1
1969 18' Caravel
Bee Cave , Texas
Zip Dee awnngs
Can anyone tell me if a large zipdee awning roller can be made smaller to fit a trailer of that size ? Thanks
Beecavetx is offline   Reply With Quote
Old 06-26-2011, 10:16 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Yeah, I think so. The roller is simply a long piece of conduit. The spring assembly is in one end, and is about 3' long. At the other end is a cap with a short shaft in it. I think you can drill out the rivets that hold the cap on that end, remove the cap and shaft, cut the tube to length, and re-install the cap. I have done all that to rebuild a roller, but did not shorten the roller. The awning is riveted to the roller so to get the roller out you have to drill the rivets that fasten the awning also. You can order parts, rivets, etc. directly from zip-dee. however the rivets they send look just like standard aluminum poprivets to me. check the zip dee site for diagram and parts list.
Old 06-27-2011, 09:36 AM   #3
1969 18' Caravel
Bee Cave , Texas
Thank you so much Bill. I thought it was possible but other people who own zipdee's said that the company said that was not possible. Thanks again. Now my search goes on for a five foot one for the streetside windows. Bob Morgan
Old 06-27-2011, 12:23 PM   #4
CAUTION WITH THE SPRING.
The rear spring on the big awning, if not "UNWOUND CORRECTLY" can and will break your arms, hands, and/or cut your neck wide open.
This is not a joke.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-27-2011, 12:23 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Absolutely. I have done it. I assume you are not talking about changing the main awning to roadside. You can also cut down a longer roadside window to fit a smaller side, rear, or front window awning. Make sure you cut the non spring side of the roller tube. Also be really really careful messing with the spring. It can be and has been an arm breaker.
Zip Dee using Silicone?????? SailAS Awnings 30 09-15-2018 11:12 AM
Zip Dee awning for '61 Tradewind 61 Streamy Awnings 10 03-27-2013 08:49 PM
No spring to my Zip Dee GaCamper Awnings 9 07-02-2011 07:36 AM
Zip Dee Ultimat crispyboy Off Topic Forum 2 05-19-2011 12:09 PM
Zip Dee Z-lock lever is stuck aname4me Awnings 4 03-17-2011 06:13 AM
