Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 06-20-2003, 07:17 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Remove Dirt Stains?
I totally removed my awning. The first part of the awning near the trailer was a rubber section that trapped in years of dirt.
So when I removed the awning it left dirt stains just under the awning rail on the trailer.
I have not polished it yet, but I prefer to get these stains off so I don't look like a total loser when we camp this season.
Standard car wash detergent and citra-strip did not work on it.
Any ideas?
-Tim
theVAP - Airstream Podcast
Old 06-21-2003, 07:06 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Remove Dirt Stains?
Greetings Tim!
I suspect that what you are seeing is actually more than just dirt or stains. What I suspect that you are seeing is more likely corrossion, oxidation, or "tarnish". The constant contact with the awning fabric (and the moisture that it may have trapped next to the skin) likely abraded away all of the plasticoat which opened the road for oxidation to begin - - this was a problem with my Overlander when the original A & E Travel Awn 5000 was removed three years ago. If what you are seeing is oxidation, then polishing is about all that will remove the discoloration - - the question becomes one of which will be more obvious - - the current oxidation or polishing to remove the oxidation that might create a brighter/glossier finish than that of the surrounding skin.
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 06-21-2003, 09:48 PM   #3
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Angry
Thanks Kevin,
That is kind of what I thought. I guess I will have to get polishing sooner than later
-Tim
Refrig-how do you remove the shelves? John Refrigerators 26 06-18-2011 10:54 AM
How do I remove the electric reel? k5cad Airstream Motorhome Forums 6 11-26-2003 06:16 PM
Remove Pine Sap from Zip Dee Sav'h Steve Awnings 2 08-05-2003 04:05 PM
how to remove ceiling lights NewStreamer General Interior Topics 18 02-01-2003 04:41 PM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 06:07 PM
