I replaced two damaged corner panels with new panels that I purchased from from Inland RV and they have a disimilar clear on them than the original 78' had.Clearcoat is not coming off with the kleen-strip on the new panels. Any suggestions? Thanks.
D.Kinsey
If your sure there's a clearcoat on them use Removall220.if thats the only have two parts that still has the clearcoat on it. you shouldnt need but maybe a qt.i think... http://www.vintagetrailersupply.com
You can also get Aircraft Remover at AutoZone and in aerosol form at Wal-Mart. For the largest part of the job on mine, I used HydroStrip 502 (ICI Paints version of RemoveAll) and a pneumatic spray gun. It's a little less dangerous to work with than the Aircraft Stripper and seems to work as well.
