I've been using the harbor freight variable speed polisher with a flannel buff pad from Lowes, but they have them at sears also. Sears also has the rouge for buffing. I'm using the red stuff (Tripoli) for the initial cut. and I bought some white rouge for a final buff (with a loose buff pad), but I don't know if I'll go that direction. after experimenting for a wihile with all the different recommendations for polishing, I tried buffing with the tripoli, then following up with a quick hand polish with Mothers, and it works pretty decent. I'm not going for the ultra shine right now. that will be later on.
I've had some experience buffing out aluminum on buffing stands, and I know that it helps to heat the metal before hand, so I've been working on it on the hot days in full sun. I don't think I'm too smart. I did try buffing on the hot side, and the cool side, and didn't notice too big of a difference. I am getting very little distortion on the hot side while I'm buffing though.
the picture of the rear shows the lines left by the buffer, and the spot in the middle is where I did the hand rub with the Mothers.
