Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 05-06-2018, 07:16 AM   #1
2008 532 International
New Braunfels , Texas
Roof Vent Covers
We have a roof leak on the aft ceiling vent. Actually, it's probably the framing on the inside of the trailer's ceiling.
I want to put a vent cover over the unit. I've shopped Amazon but before I make the purchase I'd sure appreciate some thoughts from those who have installed these units. Best brands and easiest brands to go with?
(I do NOT want to drill into the trailer's skin.)
Thanks in advance!
Andy and Nancy
25' 2008 International Ocean Breeze CCD
2002 Lariat F-250 7.3
Ext Cab Longbed
Harley occasionally in the bed.
StreamGlider is offline   Reply With Quote
Old 05-06-2018, 08:14 AM   #2
batman's Avatar
1964 22' Safari
modesto , California
You might consider removing the old sealant from around the outside of the vent, clean it with alcohol and re-seal it with TremPro or Sikaflex, polyurethane sealant. No more leak.
batman is offline   Reply With Quote
Old 05-06-2018, 08:28 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I think most vent cover instructions include drilling and screwing. There is a tape that is used for installing air conditioners that is permanent and very strong.
I am familiar with Maxx Vent. It seems like a good product.
Old 05-06-2018, 09:50 AM   #4
1976 31' Sovereign
Oswego , Illinois
I have camco covers, 4 L brackets that have 1 screw into curb of vent other leg that has carriage bolt that fastens cover. No drilling into roof only into curb of vent. First would reseal as some cover like camco sit about 1/4 from roof, no sealing tape. I don't no if other vents conform to roof or seal all 4 sides. Reason I installed is 2 vents have plastic center of cover that is old, AS vents are not sq. and did not desire to replace. And plastic vents will after time sun will crack. Add on covers will protect from elements even if vents are old.
Roof pipe vent covers and fan vent covers stormbornSG Exterior Restoration Forum 3 11-09-2016 05:27 AM
Change a metal roof vent by a transparent roof vent ? Gaël Roof Vents, Skylights & Fans 11 12-27-2014 05:55 PM
Vent covers and outside propane covers robwok 1960 - 1964 Overlander 4 02-09-2011 11:56 AM
How do I install vent covers over my vent covers? bigjohn Roof Vents, Skylights & Fans 1 07-29-2010 03:34 PM
Roof Vent Covers Dwight Roof Vents, Skylights & Fans 2 10-13-2003 10:16 AM
