Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 01-10-2010, 04:05 PM   #1
1969 21' Globetrotter
Cambridge , Massachusetts
How to remove high quality duct tape
Last spring in a hurry to close things up, I sealed shut one of the access doors with that very, very sticky duct tape, the kind with real reflective backing. HUG MISTAKE@!!! Extremely hard to remove! The temperature is in the thirtys. Do you think it will be easier when it gets warmer? If so, would a heat gun make it easier yet? With patients, I think I can scrape away the backing without scratching the aluminum but then, what kind of solvant will disolve the adhesive which thick and still very elastic/sticky. Note that the backing does not appear to have nearly enough strength to allow peeling the tape off in long strips. HELP!! Any and all ideas appreciated.
John
JoePfznik is offline   Reply With Quote
Old 01-10-2010, 04:10 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
It should be easier when it gets warmer.
Can you align it so the sun shines on the door? Duct tape wasn't meant for outdoor use and the UV will help break it down. Sounds like that has already started.
WD40 will remove the adhesive. You might try charcoal lighter fluid too.
Vaughan
Old 01-10-2010, 04:17 PM   #3
1980 31' Excella II
Drummond Island , Michigan
Warm weather will help. I used mineral spirits on a rag successfully and it did not take the finish off the trailer.
Ahzmyrah is offline   Reply With Quote
Old 01-10-2010, 04:19 PM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
When all else fails for taking sticky stuff off, Skin-so-soft Avon bath oil. it does change plastic but should work for any metal as long as metal isn't painted. I have used paper towels to hold liquid in place on flat surface, don't know about upright.
Old 01-10-2010, 05:04 PM   #5
SJ1
Gwinnett County , Georgia
A hair dryer helps to heat it enough so that it won't pull off paint or veneer.
SJ1 is offline   Reply With Quote
Old 01-10-2010, 05:33 PM   #6
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
There is a goo be gone product that will do it right away...also try 91% rubbing alcohol from walgreens ( it must be that percent) The goo stuff is in the paint dept. in any walmart...plus acetone will work too.
https://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 01-10-2010, 05:43 PM   #7
65CV's Avatar
Western , Massachusetts
or this...
3M™ General Purpose Adhesive Remover
After months of duct tape residue in the sun, this was the only stuff that worked.
65CV is offline   Reply With Quote
Old 01-10-2010, 06:13 PM   #8
Silverfoxrae's Avatar
1957 26' Overlander
Saint Augustine , Florida
Images: 45
the good stuff
Everyone needs a can of this around. It's miraculous.
Metallicised.
AIR # 42703
TCT Member
TAC # FL~6
WBCCI # 1464
'57 Overlander thread:"the end of the rainbow is silver"
Silverfoxrae is offline   Reply With Quote
Old 01-10-2010, 07:26 PM   #9
63Silver's Avatar
1963 28' Ambassador
Smiths Grove , Kentucky
Images: 43
We had 12 years of clear packing tape wrapped all the way around our trailer, about 12 layers. Nothing but Airplane Stripper would work (we tried everything) and it did a SUPER job. BUT, I would not use it on a trailer that has been sealed.
63silver
63Silver is offline   Reply With Quote
Old 01-10-2010, 09:20 PM   #10
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Avon Skin So Soft is mainly mineral oil - so try that first - it's dirt cheap.
Many adhesives come loose with
1) plain old vegetable oil
2) peanut butter - which also removes chewing gum from kids hair
Try the cheap easily available stuff first, then move up to things others have recommended. All of the above take about 5 minutes to start working.
Good luck, Paula
Old 01-10-2010, 09:48 PM   #11
"Cloudsplitter"
Thumbs up
.....Water Displacement Forty
Old 01-10-2010, 11:04 PM   #12
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
...i'd hate to be one of his patients, making you scrape off his Ducky Tape....
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
High Speed Aircraft Repair Tape JimWeilhammer General Repair Forum 1 09-27-2009 12:49 PM
How Best Remove tape striping??!! Anniedog Clearcoat, Exterior Paint & Trim 15 08-24-2009 07:27 PM
How do I remove this @#$% tape? 63Silver Exterior Restoration Forum 34 02-12-2009 07:31 PM
Removing Duct Tape Residue Lumatic Cleaning, Stripping & Polishing 24 01-11-2008 04:03 AM
Duct Tape Popup fireflyinva Off Topic Forum 10 12-05-2004 05:54 AM
