Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 06-28-2016, 06:12 AM   #41
2003 31' Classic
Terra Alta , West Virginia
Sounds like you are aware of all the angles so work with it and go camping! You have a great tow vehicle and camper. Just enjoy.
Dave
wvstreamer is offline   Reply With Quote
Old 06-28-2016, 06:18 AM   #42
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Dave
Yup.
Doug and Cheryl
Old 06-28-2016, 06:21 AM   #43
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Originally Posted by Ted S. View Post
It's goes back to my original question not one sole in the RV industry can answer:
What good is a trailer that sleeps 8 if the only thing that can tow it is a pickup?
In the trucking industry,with the big loads, we always say ,it takes iron to move iron .
Old 06-28-2016, 08:26 AM   #44
1990 32' Excella
jonesboro , Arkansas
If you have to put air bags on to support the load you either have to much load or a bad suspension. Most of your truck parts are under rated for safety. Air bags do not change the load capacity of your truck ,. They only help you ignore it. Your truck is a package . Beefing up with air bags does not address brakes, axles, axle bearings, steering assembly, and frame. Air bags do not increase the strength of these parts. That out of the way a friend of mine called local trucking co's and found one with scales. He made a donation to their coffee fund and was able to use their scales. Most asphalt , concrete, and road construction co have scales. Find out what it weighs with out loads and hitch and go from there. Good luck and remember always go to the safe side on wts and towing capacities. Good luck.
joel is offline   Reply With Quote
Old 06-28-2016, 08:41 AM   #45
FCStreamer's Avatar
2014 30' Flying Cloud
Actually, it can also be because of a specialized suspension (like the Ford Raptor).
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Tow vehicle Tongue Weight vs. Trailer Tongue Weight KeepPedaling Hitches, Couplers & Balls 10 03-23-2016 12:33 PM
Good grief... another trailer's saggy rear laducky Repairing/Replacing Floor &/or Frame 7 12-29-2014 05:15 PM
Good grief, about to go FT!! lebolewis Full-Timing 41 10-30-2014 03:57 PM
Anyone towing 27FB (7,600 lbs / 770 lbs tongue) with a V8 or TDI Touareg ? Timofeevich Tow Vehicles 41 09-23-2011 05:55 PM
Good Grief! What have we done? ND10CentCan Exterior Restoration Forum 32 03-23-2011 03:44 PM
