Old 08-14-2019, 09:36 AM   #1
1975 29' Ambassador
Hawley , Pennsylvania
75 sovereign par pump replacement
First post from a frazzled first time owner: sooo, I bought my 31 sovereign rear bath in June 2019. She’s been a trailer park queen for 15 years.( carport covered, jacked off wheels n city water and sewage hard hookups) while being in pretty darn solid shape, water pump system hasn’t been used in over a decade. Tank appears to be holding water n par pump does start and make noise. No pressure though. City hookup flows. (No check valve in place) I ordered new connection for rear bumper hookup, but haven’t installed it yet. Currently just a copper faucet dangling, but able to close to seal system. I don’t get water pulling in pre pump filter. No visible leaks and tightened clamps on old “radiator “ hoses. ( Yes. I’ll ditch the rubber soon) I was looking to replace pump with more modern, quieter unit. Any suggestions? And from what I’ve read current par has 3 wires to newer 2 wires. How would I wire it correctly? Thanks AS peeps. Pete
1975 newbie is offline   Reply With Quote
Old 08-15-2019, 03:57 PM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
I have the shurflo revolution. They claim it doesn't need an accumulator tank, but it performs much better with one than without. The silencing kit (flexible hoses) is also worth adding. With those three parts, I hardly know the pump is on.
The pump has two wires, hot and neutral. Connect the hot to the hot wire from your pump on/off switch, and the neutral to a neutral wire. That's it. The pump has an integrated pressure switch so it knows when to shut off.
TheGreatleys is offline   Reply With Quote
Old 08-17-2019, 06:08 AM   #3
1975 29' Ambassador
Wow ! So cool to see this thing actually works, (forum, not pump yet). I appreciate the reply. Pump and silencer ordered. There is an accumulator tank there. To be honest I didn't know what it was. Thought it was a filter. If it doesn't leak. leave it alone? I'm gonna try it without replacing first. So hoping water system will come to life soon.
Now if I can figure out how to resize pics so they will post..... As I know there will be 100's more questions to come.
Thanks again, Pete
sovereign
PAR water pump pressure switch needed Supertwin1 Water Heaters, Filters & Pumps 0 05-22-2014 12:25 PM
wiring on old par water pump bearhere Water Heaters, Filters & Pumps 3 07-09-2013 08:17 AM
PAR pump not working ckbailey97 Water Heaters, Filters & Pumps 9 07-14-2011 05:01 PM
Par/Jabsco Water Pump Belt? HansenClan Water Heaters, Filters & Pumps 9 06-24-2008 08:43 AM
Rebuild PAR 6800J (Jabsco 36800) or Replace with New Pump trevisgardne Water Heaters, Filters & Pumps 3 05-02-2007 09:20 AM
