03-07-2007, 07:33 AM
#21
Moderator dude
1966 26' Overlander
Phoenix
Originally Posted by Action
And yes your system is quite rare. It did not work well so many units have been converted to electric.
>>>>>>>>>>>>>Action
I amend my statement to be:
It was not a well understood system by owners so many units were converted to electric operation.
>>>>>>>>>>>>>>>Action
03-07-2007, 08:32 AM
#22
1977 31' Excella 500
Berkeley Springs
, West Virginia
E over H
Why not pitch the vacuum unit into the weeds and get a good electric over hydraulic unit to power the system? The Towbrake unit is excellent.
Since you've got the old system working, I guess it makes no sense to get an E over H unit now. I have the same system in my trailer, but I'm going to dispense with the hydravac altogether and get the Towbrake unit to power the system.
I have a diesel and have no easy source of vacuum either. It just seems to me that we get a battery to power a vacuum pump to create force to move a piston. The Towbrake unit uses battery power to move a piston. It simplifies things.
But what the hay, there's many ways to skin a cat
- Jim
03-07-2007, 09:21 AM
#23
Moderator dude
1966 26' Overlander
Phoenix
Jim,
Slightly off topic.
Your diesel most likely has a vacuum pump too. To power vacuum driven accessories if not the brake booster in your vehicle.
If you are going to remove a working hydravac system or any parts from your A/S, I bet there would be others that would want any thing that your remove. So I would suggest not pitching any of those pieces. If not for you at least for others that could use those parts.
>>>>>>>>>>>>>>>>>>>Action
03-07-2007, 10:24 AM
#24
Berkeley Springs
, West Virginia
Action,
Rest assured, anything that I remove from this coach will go on here for cheap or for free.
Being a frugal buzzard, I'm going to try to reuse as much as I can when I do my rebuild, but what I don't I will certainly try to see that it goes to a good home!
Actually, I should have realized that my truck has a vacuum pump. Doh! Maybe I can use the old Ausco's then.
I was planning to switch out everything to either Dexter or Kodiak and use the towbrake E over H. I'm not quite there yet
This summer though
Take care,
- Jim
03-07-2007, 02:33 PM
#25
Moderator dude
1966 26' Overlander
Phoenix
Originally Posted by JimGolden
Action,
Kool!
>>Action
03-07-2007, 09:18 PM
#26
1977 31' Sovereign
1992 34' Excella
Salem
Tweeking the system
Originally Posted by Excella CM
One thing you might consider, even if you mount your vacuum supply on the trailer, is a "T" in the vacuum line with a ball valve to atmosphere. This allows you to set the trailer brake by hand when you are at the hitch. I find it very conveient to "blow down" the system when I stop to adjust or inspect or park for a short period. Having the 4 wheels locked tight is added safety. I would fabricate a pump electrical over-ride to shut the vacuum pump off when the ball valve was open using a micro-switch or momentary off spring loaded button switch (you want this so you wont forget to turn it back on). This would also give you a way to shut down the vacuum pump easily. Lastly, a nice, bright L.E.D. (s) to indicate power to the vacuum pump might be good to have. I sure others can think of ways to add work for you to do, too.
Before I finish this project with the ball valve and switch, I have two more questions. I have wired the pump to a fused line to the battery but the vacuum switch needs a 12volt line also and I am wondering if I can tie into the electric jack circuit. Is it reasonable to assume I can add a switch to this circuit that would alternate power to either the vacuum switch or the jack? Is there ever a time when I would need power to both simultaneouslly?
Wayne
03-08-2007, 08:25 AM
#27
Berkeley Springs
, West Virginia
Wayne,
I think you'd be fine like that. Just remember to chock the wheels before you raise the trailer off the ball. I can't see why you'd need the brakes when you're stopped and chocked.
- Jim
