Old 04-07-2010, 11:12 AM   #1
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Brake Question
Hello all, On the first trip this season I was in the worst traffic jam ever on the way home 2 1/2 hrs. I have a cheaper tekonsha controller and I turned everything on it down in the stop and go creep of traffic. Is this the proper thing to do to prevent an overheat of the brakes or will they only heat up on the long down hill use I have read about. Robert
bertro is offline   Reply With Quote
Old 04-07-2010, 11:40 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
It really shouldn't make much difference. Stop-and-go driving in a traffic jam will generally not heat the brakes at all.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 04-07-2010, 11:48 AM   #3
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
Heat as in brakes is just energy and ,for the sake of discussion, energy can be calculated by multiplying the mass times the velocity sq'd. Higher velocity means higher energy. Thats why brakes get so hot when they slow something down from high speed. Thats why the space shuttle gets so hot on re-entry. It is converting mass and velocity to heat. Something moving at low low speed doesn't constitute much energy (or heat) when it comes time to stop it. It is extremely unlikely you will overheat the brakes creeping along in a traffic jam. You can adjust the controller to achieve a smoother stopping action, but heat will not be an issue.
So Long!
Bob Thompson is offline   Reply With Quote
Old 04-07-2010, 12:52 PM   #4
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Thank You,
I was just not sure if the power going to the magnets all the time would cause some type of heat issue.
Robert
Old 04-07-2010, 12:57 PM   #5
JFScheck's Avatar
2020 30' Classic
Derwood , Maryland
Images: 37
Now if you had "Disc" brakes - there could be an issue with the "Hydraulic" pump with some of the older units as the pump used to need to keep running every time the brake pedal was depressed - luckily within the past few years said controllers now have a "Hold" mode where the pump will energize the system then hold the pressure to the brakes - having only to run every few minutes to re-energize if the brake pedal is still depressed....
John "JFScheck" Scheck
2020 30’ Airstream Classic
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-07-2010, 02:09 PM   #6
Images: 59
I don't think you will have a problem having power going to the magnets full time.
The brake magnets have about 3 ohms resistance. Even if you applied full voltage (not the case) to the magnets, the most power they would generate is only 40 watts.
Now if you put a 40 watt light bulb in a paper bag it will burn up. But if you surround the magnet with a large cast iron brake drum and hub, I think you will be able to dissipate enough energy to keep from melting the magnets or warping the armature.
Thats my take on it. Any advice is worth what you paid for it.
Old 04-07-2010, 02:36 PM   #7
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Turning the controller down when you are stuck in slow moving traffic can actually make the trip a little more comfortable. At slow or crawl speed, the rig will stop just fine without trailer brakes and there is no grabbing.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 04-07-2010, 04:24 PM   #8
HowieE's Avatar
Princeton , New Jersey
Images: 12
If your brake controller was set up correctly there is no reason to ever adjust it do to traffic or road conditions.
There is a safety reason not to change the setting while on the road. You may suddenly brake out and travel at highway speed and have NO BRAKES when you need them.
Cehck the set up procedures for the controller and set it and forget it.
2004 Excursion 4x4
Old 04-07-2010, 11:19 PM   #9
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by bertro View Post
the brakes, or will they only heat up on the long down hill use I have read about. Robert
Hi, going down hill you need to manually down shift your transmission to a low enough gear so that you will only need to barely use your brakes or some times not at all. I have driven down many hills/mountains with out ever using my brakes. If you go down hills in overdrive, you will for sure, burn up your brakes on your tow vehicle and trailer.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 04-08-2010, 01:32 AM   #10
Maniacal Engineer
barts's Avatar
Lopez Island , Washington
Remember to shift into neutral when sitting in traffic jams for those of you w/ automatics... otherwise they overheat. Your brakes won't overheat, though...
- Bart
Bart Smaalders
Lopez Island, WA
https://tinpickle.blogspot.com
barts is offline   Reply With Quote
Brake Question milesmason Brakes & Brake Controllers 5 03-12-2010 10:19 AM
Brake question 63air Brakes & Brake Controllers 1 10-08-2009 06:58 PM
Brake Question Zac&Kristin Brakes & Brake Controllers 1 06-18-2009 07:59 PM
brake question PLEASE HELP airstreamer Brakes & Brake Controllers 11 05-30-2007 04:38 PM
Brake question mtnman All Argosy Trailers 13 12-11-2005 08:42 AM
