Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 07-20-2011, 07:38 AM   #1
1988 29' Excella
Waco , Texas
Mismatched spare size
Hi, I just bought my rig and didn't get a spare. It has 7.0x15 tires on it that are in great shape, and I don't want to replace them. I can't find the same size spare in my area. We're leaving for our first long trip this weekend. Does anyone see a problem with having a 225/75 for a spare.
Thanks.
crios is offline   Reply With Quote
Old 07-20-2011, 07:56 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
For short haul, no problem.
Old 07-20-2011, 08:00 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I use 700 x 15 and have no trouble finding them. I use bias types. Any good tire shop can help. And, they should be able to give you accurate advice on comparable diameter tires if you need it.
Old 07-20-2011, 08:42 AM   #4
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Might be a good idea to get the numbers off those tires and just see how old they are. IF they are 6 or 7 years old,it might be a good idea to replace them before you embark on a long trip. Save yourself a lot of agrivation and damage to your AIRSTREAM . JUST A THOUGHT
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 07-20-2011, 08:47 AM   #5
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Thanks.
I got our tires 7.00 x 15 at Sams' Club. Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 07-20-2011, 09:04 AM   #6
"Cloudsplitter"
2nd the comment on tire age, 100 degree air temps probably translate to 200+ blacktop which is a real concern, especially for older rubber.
Stream Safe
Old 07-20-2011, 02:15 PM   #7
2005 19' Safari
GLENDALE , AZ
It was 112 degrees here the other day. Before driving, the tow vehicle tire in the shade measured 124 degrees (had been in the sun earlier in the day), and the tire in the sun was 162. After driving about 50 miles, all were 128 to 132 degrees, lower than expected. Didn't measure temperature of roadway. Unfortunately, we didn't have our Bambi in tow.
Snap Size '65 Tradewind? P&A Upholstery, Blinds, Walls & Interior Finishes 2 07-16-2011 03:27 PM
POLL: AC BTUs, Trailer Size, and Climate Shiloh Furnaces, Heaters, Fireplaces & Air Conditioning 19 05-14-2011 10:51 AM
Spare Tire Mounting question polarlyse Tires 5 05-05-2011 07:31 AM
Tires and tire size KyMoonshine Tires 5 03-08-2011 04:28 PM
waterlines size qc1500 Fresh Water Systems 8 01-11-2011 06:04 PM
