Old 06-08-2015, 01:49 PM   #1
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
A TV tire question
Another question while there is some tire guru's around....
I have a F150 as a TV and I'm considering changing out the tires that came with it from the factory. Right now the truck has "P275 55R20 111S Tires and I'm thinking about going to an LT tire possibly a Michelin. Does anyone have any recommendations and will an LT tire actually increase my truck Payload if I choose the correct tire?
I see Michelin has a Cross over Light Truck tire called a LTX/MS2 or possibly the LTX A/T2. I have no idea if these are what I should be looking at or not.
275/55R20 Tires | Michelin Tires
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 06-08-2015, 10:49 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Doug
The answer is NO. Tires no matter what the load capacity greater than the load capacity of the truck does NOT increase the load capacity of the truck. The load capacity of the truck effects far more items than tires.
Restated, if the gross vehicle weight rating (GVWR) is 5000 pounds and some one installs tires with a load capacity of 8000 pounds the max load capacity of the entire truck with load is still 5000 pounds. Any total vehicle weight greater than 5000 pounds is overloaded.
One would want to match the tire load capacity to the maximum possible vehicle load. (Or GVWR) Anything greater than that is OK just don't load the vehicle gretaer the GVWR because there are other assemblies that were only created to the max GVWR. Like springs, shocks, brakes electronic suspension and brake compoenants to name a few.
>>>>>>>>>>Action
Action is offline   Reply With Quote
Old 06-09-2015, 02:24 AM   #3
Vintage Kin
Fort Worth , Texas
Wheel rating needs to match and preferably exceed tire rating.
Old 06-09-2015, 03:16 PM   #4
Ravenna , Ohio
Doug
Using any "P" type tire requires you to "de-rate" the tire load capacity by dividing by 1.10.
Many of the "LTX design" sizes are actually just "extra load" Passenger tires and not really LT type tires.
I wrote a blog post March 2 on "Much Confusion" discussing the "LTX' name and line of tires.
Retired tire engineer (50 years). Write a blog on RV Tire Safety Net. Give seminars for FMCA across the US. Tucson AZ in Mar 2024 is next.
Tireman9 is offline   Reply With Quote
Old 06-10-2015, 10:21 AM   #5
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
Fox
You cannot go wrong buying the Michelin LTX/MS2 tires. I get 70,000+ miles on them on both my Tahoe and Yukon...and have never had a tire failure. Cost a little more...but so well worth it. jon
B00merang is offline   Reply With Quote
Airstream Tire Poll for Travel Trailers with NO Tire Failures Phoenix Tires 5 01-09-2015 08:11 AM
Blown tire-Discount Tire sold me Carlisle?? FLYNCLD Tires 15 08-22-2010 09:45 AM
help with measurments from tire to tire '67 Caravel Trophycare General Repair Forum 0 07-19-2010 11:17 AM
Tire protection, tire cover and airconditioning leong1 Tires 0 06-22-2009 04:02 PM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
