11-20-2018, 01:52 PM
#41
2018 25' Flying Cloud
Roseville
Dual A/C
We bought our 2018 FC 25 "off the lot" equipped with dual A/C; our one hesitation was that we thought the extra cost of the second unit was wasted of $$ on a trailer that size. BTW, we live in the Sacramento area; i.e. hot summers!! The first time we were prepping the trailer for a trip we thanked the lucky stars that we "accidentally" ended up with the dual system. We try not to travel to hot places. but if just for prepping for a hot season trip and keeping the inside comfortable and the fridge cold, it's worth its weight in gold and we'd never buy another w/o it!
Larry
02-19-2019, 01:44 PM
#42
1994 30' Excella
Franklin
, Ohio
When you have 2 units are both units the same Btu.i have 30’ bed room maybe 8’ x 8’ and definitely need more capacity it would also be a backup if one quits.
02-19-2019, 01:59 PM
#43
2012 Avenue Coach
Corpus Christi
It's your choice. Both units could be 15K (instead of both 13.5K or one of each) so long as you buy an efficient unit. For example, I recently replaced a 6 yr. old singe 13.5K in my class b with a new 15K. The new model is more efficient and uses .5 to 1A less the the older smaller unit.
02-19-2019, 02:15 PM
#44
Cincinnati
, Ohio
No, not the same when ordered on a new unit. One is 15k and one is 13.5k.
Edit: Upon second look I see you have a 1994 Excella. If the electrical can handle it you could probably choose which size you want to add. I imagine if yours came with one then your Excella isn't wired for a second one. Could get expensive.
02-19-2019, 02:20 PM
#45
1969 29' Ambassador
1985 31' Excella
1969 29' Ambassador
Crescent
, Oklahoma
I have a 69 Ambassador, currently gutted. Has anyone ever added one on a vintage. Ive considered it, but where? Original is about dead center, and rear vent is almost at endcap. Seems like I’d have to relocate both?
Have a blessed day !
TAC OK-5
02-20-2019, 06:22 AM
#46
1994 30' Excella
Franklin
, Ohio
I have 30 amp power. 2 units would require 50 amp 220 which would require a 4 conductor #8
Has anyone fished a cable from lower storage compart to uper storage where breaker panel is located? Or located panel to other location cable?
02-20-2019, 10:23 AM
#47
2019 33' Classic
Estes Park
2 15000 btu
02-21-2019, 04:26 AM
#48
2010 27' FB Classic
Austin
I had a second unit added to mine and they just added a second outside 30 amp service that feeds only the new unit. I put in a switch that allows me to use either unit off of one cord. If I want both units, I use two cords.
You only need 2 units above 90 degrees, so most of the time I only deal with one 30 amp cord. They are much nicer to work with than the 50 amp cords. Also, my 30 amp "generator" plug in the front of the camper still works as designed.
It cost less than half of what the factory charges for the upgrade.
2010 27FB Classic
1989 190 Class B (Sold)
1977 29 Ambassador Land Yacht (Sold)
02-21-2019, 06:10 AM
#49
1994 30' Excella
Franklin
, Ohio
Great idea
I like that idea.
I already carry a 30 amp 25’ extension cable that i could use to plug in with.
Do you have a 2nd breaker box mounted?
02-22-2019, 05:00 AM
#50
2010 27' FB Classic
Austin
I like that idea.
Yes, I did get one new 30 amp breaker on the new incoming line. In my 27FB Classic, the switch and the new breaker ended up in the little cabinet under the refrigerator.
I am not sure your extension cord will work with the twist lock on the side of the trailer.
2010 27FB Classic
02-23-2019, 04:23 PM
#51
1994 30' Excella
Franklin
, Ohio
We are in south west Florida this month and the last week has been in 90 with high humidity. I have lined all windows and sky lights with the silver insulation and one AC is not working. Today I closed both doors going into bedroom and that helped but bedroom was very warm. But best i can tell 1 unit will no work in this heat and humidity.
02-23-2019, 09:16 PM
#52
2016 28' Flying Cloud
Auburn
, Alabama
Did you get that done at an airstream dealer? And if you don’t mind me asking, what did it cost? I have a 28FC with one AC and was thinking of adding another unit.
02-24-2019, 09:13 AM
#53
1994 30' Excella
Franklin
, Ohio
Anyone documented how to install 2nd AC?
Has any one found a tread that discussed the installation of a 2nd ac unit
I know 12 volt power is there but can power wire and drain tube be fished up through wall?
I have serched airfoums but not found anything.
02-24-2019, 01:02 PM
#54
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
I am going to semi-settle/snowbird in the deep south and know my single 13.5 K unit will sometimes be inadequate for the 25 FB. I am replacing the 13.5 K with a 15 K. If I need more capacity, I will go the super cheap route, adding a small window unit or roll around unit in the bedroom, vented out the front window. I can power it with an extension cord to the 20 amp outlet on the post... and pull it and store it when I travel to temperate areas.
02-24-2019, 01:36 PM
#55
2017 28' International
Jim Falls
, Wisconsin
Another advantage of 2 units: When 2 units aren’t needed if you are sitting in the “lounge” area you can turn the one in the bedroom on and there isn’t as much noise. Then when you go to bed you can turn the other unit on in the lounge area and the one above the bed off. Quieter to sleep, but still stays cool. Also I am in WI so it’s nice to have the heat pump set up that way too.
Get 2. You will never regret it.
02-24-2019, 03:46 PM
#56
2010 27' FB Classic
Austin
Camper Clinic in Buda Tx between San Antonio and Austin. It was $3,600.
2010 27FB Classic
03-03-2019, 08:57 AM
#57
2019 25' International
Fernandina Beach
Originally Posted by moosetags
I guess that I will be the one dissenting opinion on this topic. Let me start by saying that we are somewhat experienced Airstreamers. We have almost 2,000 nights of Airstream camping over the last twelve years. We have camped all over the country in all types of weather conditions. We have had two 25FB's, a 2005 and a 2015. Both were equipped with a single 15,000 btu air conditioner.
We do take certain precautions in hot weather camping. We keep the bedroom and large streetside windows covered with the silver window insulation. We also cover the skylight with insulation during the summer.
I am not trying to talk anyone out of adding a second air conditioning unit in their Airstream. I am simply stating what has worked for us in the long haul.
Brian
Thanks Brian!
03-04-2019, 04:43 PM
#58
Central
, Mississippi
I added a 2nd ac to my 34'
http://www.airforums.com/forums/f205...tml#post839907
Who would have thought that 1 ac would ever be enough on a 34'!!'
03-08-2019, 06:50 PM
#59
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
That will work. We generally camp where we don’t need AC, but when it is needed I take the small efficient light weight unit out of the closet and install it in the window. You may not even need the main AC unit at night- nice quiet sleep.
I am also renovating a 34’. I hate the loud AC. I plan on installing a 12k mini split heat pump. If more capacity is needed I will install a 5k window unit in the bedroom.
Dan
03-28-2019, 05:03 PM
#60
1994 30' Excella
Franklin
, Ohio
Penguin ll 1500 BTU
I was looking for the correct model number to replace my 1300 BTU unit.
Dose anyone know the model number for a domtic penguin ll 1500 BTU With heat strip and drip pan adapter to keep drain line connected
Also ther are multiple inside units I’m looking for thermostat monted in lower unit and the discharge air coming out front and rear not the sides. Looking on sites ther are many different configurations.
My unit is a 30’ 1994 looking to maintain same low profile
Any help would be greatly appreciatied
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Armstrong RV Air conditioners
pap |
Furnaces, Heaters, Fireplaces & Air Conditioning |
101 |
10-12-2022 12:27 PM |
Atwood Air Command Air Conditioners
Lumatic |
35 |
10-08-2020 08:14 AM |
1 Micro Air 2 Air Conditioners | Dilemma
MarkJUrban |
Electrical - Systems, Generators, Batteries & Solar |
17 |
10-30-2018 02:43 PM |
HOT Topic for the summer-Air conditioners-Best/worst?
thenewkid64 |
4 |
07-03-2002 04:55 AM |
Air Conditioners
JAG |
2 |
03-19-2002 01:25 PM |
