Old 03-28-2019, 05:41 PM   #61
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
We took Moosetags advice to get one A/C and the three-sided awning option when purchasing our custom ordered 2017 25' Airstream. I guess those of us from Florida like the heat. We typically dry camp, always use the two fantastic fans, and rarely use the A/C. We typically leave Florida from May to September to escape the summer heat and humidity, but have never been uncomfortable with our single A/C even at very high temperatures and humidity levels. We would definitely only get one A/C on a 25' if we had to replace our Airstream. Also 50A service is not useful to us dry campers as our generator only has a 30A plug. When dry camping in hot temperatures, especially when traveling for the day, we occasionally run our generator and A/C for an hour or two before going to bed so we can sleep comfortably. We actually run our furnace all night long most of the year. Remember, we are from Florida and don't like being cold.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 03-28-2019, 08:04 PM   #62
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Originally Posted by Ditter View Post
I was looking for the correct model number to replace my 1300 BTU unit.
Dose anyone know the model number for a domtic penguin ll 1500 BTU With heat strip and drip pan adapter to keep drain line connected
Also ther are multiple inside units Iím looking for thermostat monted in lower unit and the discharge air coming out front and rear not the sides. Looking on sites ther are many different configurations.
My unit is a 30í 1994 looking to maintain same low profile
Any help would be greatly appreciatied
..heat strip? Old school...go with a heat pump...
Old 03-28-2019, 08:26 PM   #63
2007 31' Classic
Gulf Breeze , Florida
Originally Posted by Foiled Again View Post
I am going to semi-settle/snowbird in the deep south and know my single 13.5 K unit will sometimes be inadequate for the 25 FB. I am replacing the 13.5 K with a 15 K. If I need more capacity, I will go the super cheap route, adding a small window unit or roll around unit in the bedroom, vented out the front window. I can power it with an extension cord to the 20 amp outlet on the post... and pull it and store it when I travel to temperate areas.
Those roll around units are noisy. I have an LG 9000 for my workbench. Iíll sell it for $150 if you get to Pensacola.
trumpetguy is offline   Reply With Quote
Old 03-28-2019, 08:29 PM   #64
Overkill Specialist
GMFL's Avatar
2020 30í Globetrotter
2014 23' International
Dadeville , Alabama
Hereís what I installed.
Hereís the Blog post.
http://www.airforums.com/forums/blog...all-done-2974/
ID:	336796   Click image for larger version
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Armstrong RV Air conditioners pap Furnaces, Heaters, Fireplaces & Air Conditioning 101 10-12-2022 12:27 PM
Atwood Air Command Air Conditioners Lumatic Furnaces, Heaters, Fireplaces & Air Conditioning 35 10-08-2020 08:14 AM
1 Micro Air 2 Air Conditioners | Dilemma MarkJUrban Electrical - Systems, Generators, Batteries & Solar 17 10-30-2018 02:43 PM
HOT Topic for the summer-Air conditioners-Best/worst? thenewkid64 Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-03-2002 04:55 AM
Air Conditioners JAG Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-19-2002 01:25 PM
