yes, once you can lower the inner shroud and the framework that's against the ceiling, the AC lifts off with just two (or three) connections--drain tube, 110 V, and thermostat wires.
All the A/C units that I have encountered are held on by bolts which pass through inner opening. The other issue you will encounter most likely is a gasket that seals the A/C unit to the top of the pan or trailer. It will be destroyed as you lift the unit off.
Jack
Jack Canavera
STL Mo. AIR #56 S/OS#15
Bob, this thread describes the procedure: http://www.airforums.com/forum...ick+gasket+air
but note post #14, where the need to cut gaps in the gasket is described. It caught me out first time round.
Nick.
