Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1969 - 1973 Safari
Old 05-01-2019, 06:01 AM   #41
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Sounds like you have the Charge Line wire in the 7 way plug connected to the turn/brake light on the one side.
When you replaced the 40 amp fuse in the TV the charge line was energized.
More circuit ID is required.
Old 05-02-2019, 07:40 PM   #42
RichHog's Avatar
1972 23' Safari
Houston , Texas
Problem finally solved. Went to Master Hitch here in Houston and within minutes two guys were working on the trailer and Tow Vehicle. One guy took apart my carefully required 7 pin plug and started working it like a rubric cube. Wires coming off and then reassembled in the correct order. They rolled up a portable diagnostic cart that had all of the car light functions on it so they made sure the car was good then started testing the trailer wires. It was like a pit crew at the races. Then one man moved to the tail light and replaced the bulb and worked on the light fixture. Then did the license plate light and marker lights. They would have fixed those if I had time to leave it. And now electric brakes are 100%. So lesion is to hire a pro on these things. It’s great to drive around town with turn signals, brake lights and everything working. Master Hitch gets 5 stars from me.
RichHog is offline   Reply With Quote
Old 05-02-2019, 07:42 PM   #43
RichHog's Avatar
1972 23' Safari
Houston , Texas
It was a 140 Amp fuse. And I believe it was turn light/brakes. Brown Wire.
Running lights working but no brake lights etc. jhuggins76 Lights - Interior & Exterior 16 05-14-2017 09:37 PM
Urgent Help....No Brake Lights when running lights are on Debnw Lights - Interior & Exterior 10 05-08-2015 03:04 PM
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
1976 Argosy 28 Brake lights, turn signals, running lights not working!!! Argosy1976 Batteries, Univolts, Converters & Inverters 6 06-22-2012 05:20 AM
Should interior lights work with no battery but with Tow Vehicle connected bocotim Electrical - Systems, Generators, Batteries & Solar 12 11-03-2011 10:06 AM
