Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 07-22-2019, 09:45 AM   #1
Retired Fishing Guide
Cap-N-Red's Avatar
2005 28' Classic
Port O'Connor , Republic of Texas
Low Voltage
I have noticed more RV parks have voltage that I consider low. Just a question.
At what point as far as volts go , does low voltage become hazardous to electrical equipment in your trailer or RV. ? I’ve heard it’s about anything below 105 volts. Does anyone know the answer for a safe number on the voltage scale. In the past if it is below 110 without anything on , i’m OUT OF HERE.
Cap-N-Red
2018 GMC CC D/A
2005 28' Classic
WBCCI # 3133
Cap-N-Red is offline   Reply With Quote
Old 07-22-2019, 11:07 AM   #2
batman's Avatar
1964 22' Safari
modesto , California
I believe that in general the optimum VAC is 120 vac here in the good old U.S,A. The accepted variance would be plus or minus 10%. 108 vac minimum, 132 vac maximum. Voltages will vary under load.
However each of the appliances (refrigerator, air conditioner, microwave, heater. etc.) all have listed perimeters of operation. Check each to verify what voltages will be safe for your application.
Anything with an electric motor will suffer and potentially reducing the lifespan of that motor, i.e. Referigerators, air-conditioners.
-Dennis
batman is offline   Reply With Quote
How low a voltage is too low??? SagaCapt Batteries, Univolts, Converters & Inverters 20 07-23-2019 06:43 AM
how low is too low AC voltage? WineStream Electrical - Systems, Generators, Batteries & Solar 64 07-16-2018 08:57 PM
Low-Voltage Battery Alarm rseagle Electrical - Systems, Generators, Batteries & Solar 14 04-19-2006 08:19 PM
Low voltage-A/C Dave-O Electrical - Systems, Generators, Batteries & Solar 10 04-24-2003 07:56 PM
Low Voltage Problem kellyw Electrical - Systems, Generators, Batteries & Solar 3 10-23-2002 06:35 PM
