Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 01-19-2004, 05:49 PM   #1
MileHigh
Profile:
Info Request from Suburban Owners
I am getting ready to purchase a Suburban which will be used as a family vehicle, as well as tow my 29ft Excella (gvw 6800).
............I "Think" I have narrowed it down to:
1. 1/2 ton Suburban with Vortec 5300 and 4.10 rear-end, or
2. 3/4 ton Suburban with Vortec 6000 and 3.73 rear-end.
I'm interested in adequate performance of course,..but I'm looking at fuel economy as well, as most driving will be done around town.
Since I have a choice,....I want to choose the best "overall" configuration.
I don't want to have to use "Premium" fuel,..and I don't need that large Vortec 8100.
The Dealers I've talked to here in Denver, don't seem to know "Squat" or have a clue about "approximate" fuel comparisions of the two vehicles.
They say GM does'nt provide that information.
I'd prefer to Trust a Suburban "Owner's" opinion from this Forum
anyway, in helping me decide,..over that of a salesman who does'nt know anything about towing an RV.
Thank-you for taking the time and sharing your preference and opinion...
Rick
MileHigh is offline   Reply With Quote
Old 01-19-2004, 07:00 PM   #2
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Greetings Rick!
I have owned my '99 GMC K2500 Suburban since April 24, 1998. It was special ordered for me by my local dealer - - it has served me well now for 122,000 miles and I am anticipating at least 300,000 miles before a replacement is even considered. It was ordered primarily as a tow vehicle for my '64 Overlander International (Gross Weight of 6,100 pounds with a hitch weight of 750 to 775 pounds).
The Suburban has the 7400 VORTEC and 4.10 differentials. My previous tow vehicle was a K1500 Z-71 club cab pickup with 5700 V8 and 3.73 gearing. The difference between the two vehicles is remarkable - - the Suburban achieves better MPG than the K1500 did under all conditions by at least 1 MPG, and it is a far superior tow vehicle in the mountains - - I frequently travel to the Rocky Mountains and have never been dissapointed by the Suburban - - unfortunately the K1500 Club Cab couldn't make the Eisenthower Tunnel grade -- it was down to under 20 MPH in low gear and obviously struggiling - - it was traded almost immediately upon return from that trip (at only 55,000 miles) on the Suburban.
If long-term durability is an issue, I would suggest getting the 2500 series with the largest motor (and numerically highest differential) that you feel comfortable with. My experience has been that the vehicle operated significantly below its maximum trailer tow rating offers much greater long-term durability - - my maintenance expense for 122,000 miles on the K2500 Suburban has actually been about equal to the maintenance expense for the K1500 Club Cab for 55,000 miles.
While I know my '99 Suburban has a slightly different engine/transmission combination, I can offer the following based upon the 7400 VORTEC, 4.10 differentials, and heavy duty overdrive automatic:
Solo fuel economy: 13-16 MPG
Towing fuel economy: 10-13 (Overlander) 12-14 (Minuet)
With my previous K1500 Club Cab with 5700 V8, 3,73 differentials, and standard overdrive automatic:
Solo fuel economy: 12-15 MPG
Towing fuel economy: 9-10 MPG (Overlander)
My daily drive is 7.5 miles of suburban highway, and MPG figures include twice monthly trips into the cities as well (120-150 miles of urban travel).
Good luck with your decision!
Kevin
Kevin D. Allen
AIR #827
Old 01-19-2004, 07:27 PM   #3
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Get the 8100 or the Duramax.
5.3 does not have it where it counts for that size coach. The 6.0 is still marginal but if that's the only two you will concider then go with it. This is big time truce wit hthat thin air you got.
My 88 Suburban 454 gets the same MPG as my 79 Blazer with 350 and 1000lb less weight. There is a point were the weight is better served by a bigger more powerfull engine and since it has to ork less hard it will get better economy. I have pulled a 305 out of a Camaro one time that ran just fine with about 50k on it. It was replaced by a est 400hp 383. Car picked up 1.5 mpg when you kept your foot out of it and even with your foot in it it never got any worse MPG. It was running the same carb that had been rejeted and ran high 12 low 13's at the strip.
If MPG is that important then go to the Durmax. Empty you will be turning 20mpg. At some point that will make up for extra $3.5k puchace price.
When I toast the 7.4 if I have the 88 that long it's getting a Durmax and Alison. Prices will be down by them. Looking at a 87 wrecked 6.2 deisel for a DD right now. $100 and it's mine. About $400 more an it will be road worthy $100 to fix the A/C. hehehe. $50 for flat black paint to scare folks.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 01-19-2004, 07:33 PM   #4
MileHigh
Profile:
Suburban Info
Thanks Kevin, for taking the time to respond.....
Rick
Old 01-19-2004, 07:37 PM   #5
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Rick,
The 6 litre engine really likes the 4.10 rear end according to those on www.pickuptruck.com who pull trailers. I think it would be a better choice for you if you can get that option.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-19-2004, 07:44 PM   #6
Davydd
Davydd's Avatar
Profile:  Tonka Bay
Images: 13
Suburban Trailering Comparison
Rick,
The Suburban 5300/4.10/2WD combination is rated to pull a maximum trailer weight of 8800 lbs., whereas the 6000/3.72/2WD is trated to pull 8300 lbs.
I had a 5300/4.10/4 x 4 Silverado and liked it very much. I averaged (non-towing) about 17-19 mpg on the highway and got as much as 21 on occassion. The 5300 runs on standard 87 octane.
I currently have a Trailblazer L6/4.10/4 x 4 and the fuel mileage is rated the same as the 3.73 rear end so I doubt there is much difference in the rear end ratios as there is in the different engines.
Davydd
Pleasure-Way Plateau Sprinter B Camper Van
2004 Nissan Titan LE Crew Cab
(Former vintage Airstream Owner)
http://www.tonkawoods.com
http://www.porktenderloinsandwich.com
Davydd is offline   Reply With Quote
Old 01-19-2004, 08:28 PM   #7
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
6.0 with 4.10
toaster i have to disagree.
rick,
i also have a 29 foot excella (1992 model) and currently tow it with a 2000 chevrolet silverado 3/4 ton 4x4 truck with the 4l80E transmission and 6.0 motor.
it is far and away the best truck i have ever towed this trailer with! and i also toss my 1955 harley davidson in the back of the truck. it gets decent milage for a truck of it's size.
in the past i have towed the trailer with the following:
'88 1/2 ton chev 4x4, struggled
'89 1/2 ton chev 4x4, also struggled
'92 1/2 ton suburban 4x4, struggled but was comfortable
'96 1/2 ton chev 4x4, struggled but color matched trailer
'97 1/2 ton chev diesel (8600 gvr), towed great!
i would reccomend the suburban with the 6.0 and 4.10 gears if you can get it. 3.73's would work as well because you won't be tempted to haul anything as heavy as a harley in the back! the half tons did o.k. but felt overwhelmed by the trailer.
john
you call them ferrets, i call them weasels.
Old 01-19-2004, 08:44 PM   #8
alan
Profile:
Suburban
I have an 03, 3/4 ton Suburban with the 6.0 and 3.73 rear. I pull a 25 ft Sovereign (about 6,000 lb).
I am very satisfied with this combination. I typically tow in 3rd gear at 60 mph. Fuel economy averages just under 12 mpg towing. Mountain grades are not a problem.
I use the Suburban for commuting, and average about 14 mpg. Traveling empty, fuel economy is 16 - 17 mpg.
alan is offline   Reply With Quote
Old 01-19-2004, 08:49 PM   #9
drcharles2
Air # 3974
Profile:  1986 34' Excella
south bend , Indiana
Dear mile high,
You've received many good suggestions. I would opt for the duramax 6.6 liter diesel with the incomparable allison transmission. You never want to travel underpowered. Even though you may not intend to pass a Kenworth hauling logs at 80 mph, it's comforting to know that you could if you wish.
The excess power is neither an unleashed endorphin nor latent testosterone envy, just good common sense. You may choose to buy a heavier unit some day, or be asked by friends to haul 10-12M lbs. Comes in handy, 20 mpg when traveling a capella, and 10-13 mpg with your AS in tow, depending on the wind.
Dr. C.
drcharles2 is offline   Reply With Quote
Old 01-19-2004, 09:01 PM   #10
dinoburb
dinoburb's Avatar
Profile:  1982 34' Limited
Tidewater , Virginia
Based on your request . . .
The vehicle to choose would be the 2500HD w/6.0 and 4:10 gears. Its just going to pull that trailer a lot easier than the 5.3. The torque curve on the 5.3 is higher than on the 6.0. The 6.0 is much better suited to hauling than the 5.3. The fuel ecomomy difference between the 3.73 qnd 4.10 is miniscule but the reduction in pulling strain can be felt.
Your dealer HAS the charts and necessary information to assist you. Force the issue. He is trying to sell what he has already floor planned and does not want to order another truck. Moving inventory on the floor is his goal. Getting the best truck for your purpose is your goal. Don't lose sight of that!!!
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
dinoburb is offline   Reply With Quote
Old 01-21-2004, 08:53 AM   #11
Diesel Pusher
Diesel Pusher's Avatar
Profile:
I think you should get the 3/4 ton suburban with the 8.1 or the 6.0. The more power you have, the better the mileage you will get.
The more power avaialbe means the less rpm's the gas engine has to produce to tow your trailer. If you got the 5.3, you would be eating fuel with the high rpm's needed to achieve maximum torque which would be about 330 pounds per foot at 4,000 rpm's
The 8.1 would produce more torque perhaps at a lower rpm thus saving some fuel and stress on the engine.
I tow my 31 foot excella with a 2001 dmax and love it. If I could get a dmax in a suburbabn, I would trade my wife's z71 tahoe in for it. The diesel is a pulling monster and I average consistently 15 mpg pulling the trailer and get 17 - 19.50 consistently without the trailer. Occassionally it will get over twenty if I keep my foot out of it.
Good luck to you. You will like the Suburban.
1977 A/S Excella 500, 31 foot
2001 2500 HD D/A 4X4, Ext. cab, Victory Red.
Diesel Pusher is offline   Reply With Quote
Old 01-21-2004, 09:22 AM   #12
RivetED
RivetED's Avatar
Profile:  2005 25' Safari
Hillsboro , Texas
Over 20 yrs. towing 'toys' around with 1/2 ton units, all gas with different engines, I have recently purchased a diesel for our heavy-but-not-full-time travelling. We are both recently retired. All of the three U.S. major manuf. produce excellant trucks.
If you have to have gas, IMHO, a GM large block V-8 would be my choice. BTY: I bought a Ford diesel.
One way or another Get the heavy-duty power! With over 25' trailers, you'll appreciate it.
-Good Luck
RivetED is offline   Reply With Quote
Old 01-25-2004, 11:12 AM   #13
53flyingcloud
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
1964 19' Globetrotter
1953 21' Flying Cloud
Amherst , New Hampshire
Since you asked
This is not a gasser but, rather a diesel..Just another option..
With my Burb 2500, 6.5td diesel, 4x4 with a 3.73..Towing a 29' A/S.
  • 1.While towing: Average is between 14 to 16 mpg.(depends on terra firma)
    2.Without the A/S in tow: Hiway driving: 19 to 20mpg.
    3. Stop and go around town: 15 to 16 mpg.
Since I have the larger tank (42 gallons), the refill cycles are fewer on long trips.
FWIW..
Good luck on your choice~
ciao
AIR 807
53flyingcloud is offline   Reply With Quote
Old 01-25-2004, 11:31 AM   #14
Navigator
Profile:
According to my calculations, and assuming that the price of diesel is the same as gas, and you get 7 mpg more out of diesel, then you have to drive 64K miles to break even, at the incremental cost of a diesel engine.
Dick
Navigator is offline   Reply With Quote
